car won't start.
Old Apr 12, 2008 | 06:27 PM
Del Sol S's Avatar
Default car won't start.
me and my friend just did a compression test on my 93 del sol today and after we put back everything in place, it started for about 5 seconds and the engine died and it rotates/cranks but won't start. I've check the fuel pump and it's working. Also pulled the plug and check for spark but there was none. No CEL either. It has a D15B7 engine.
Old Apr 12, 2008 | 08:37 PM
Del Sol S's Avatar
Default Re: car won't start. (Del Sol S)
Anybody?help please
Old Apr 12, 2008 | 09:55 PM
Former User's Avatar
You possibly have a bad coil or igniter unit in the distributor. Also check for blown fuses and whether the ground wire on the thermostat housing is securely attached and not corroded.
Old Apr 12, 2008 | 10:21 PM
Del Sol S's Avatar
Default Re: car won't start. (RonJ@HT)
I'll check that tomorrow. Do you think it might also be a bad ECU/Computer Box.? How to test the ECU if its working?
Old Apr 12, 2008 | 11:19 PM
obuhmyuh's Avatar
i think you fried your ecu... one way to check... plug in the ecu that isnt working and turn your key to ON (dont start it), and if you cant hear the fuel pump prime then my guess is its your ecu. i fried a few like that.
ALSO, CHECK YOUR ECU FUSE!!!
Old Apr 13, 2008 | 01:07 AM
Christian23's Avatar
Default Re: car won't start. (obuhmyuh)
check ecu spark plugs maybe even
BSG
87
May 13, 2013 09:12 AM
hybridmath
30
Jul 20, 2008 03:38 PM
93DA530
Nov 24, 2003 11:10 AM
AgentJam
17
Aug 27, 2003 06:54 PM
lude97dude
Jan 21, 2003 08:53 PM
