1996 OEM Foglight install
Old Apr 12, 2008 | 05:58 PM
AP96's Avatar
Default 1996 OEM Foglight install
On my OEM foglight kit, what do I all need to plug in? Nothing in the fusebox will plug in or vise versa. Also I can't find any good wiring diagrams. Please help!!
I already searched and nothing came up.
Thanks for the help ahead.
Modified by AP96 at 8:27 PM 4/12/2008
Old Apr 12, 2008 | 06:08 PM
umop-apisdn's Avatar
http://www.hondaautomotivepart....html
Old Apr 12, 2008 | 08:49 PM
AP96's Avatar
My switch harness is different than the one that is posted. Are there any more diagrams, mainly for the OEM Accord 5th gens?
Old Apr 12, 2008 | 09:48 PM
TheMuffinMan's Avatar
He knows where you live!
You didn't search
Old Apr 12, 2008 | 10:01 PM
AP96's Avatar
I have, I haven't found anything. I think they may have shipped me the wrong harness now that I look over everything again.
I say that because none of the plug ins will go into the fuse box.
Old Apr 12, 2008 | 10:04 PM
SuShiBoiiii's Avatar
Default Re: (AP96)
interior fuse box?
https://honda-tech.com/zerothread?id=2202682
You probably bought a DEPO set or have a DEPO harness.
Both installs are in that thread. It's the 2nd one that comes up with "fog"
Sushi, the OEM fogs go to the hood fuse box, you unplug one of the existing and plug the fog harness in series with it.
Old Apr 12, 2008 | 10:05 PM
dleccord's Avatar
pics after install?
Old Apr 12, 2008 | 10:09 PM
AP96's Avatar
After reading one of those threads one of the plug ins plugs into one of the ports in the hood fuse box?
Old Apr 12, 2008 | 10:11 PM
The OEM honda install guide is in that thread I just posted.
Yes it gets plugged into the under hood fuse
Old Apr 12, 2008 | 10:13 PM
AP96's Avatar
Thank you so much for posting that.
I'll get pics after install!
Old Apr 12, 2008 | 10:15 PM
Did you buy it new?
If so it should have an "A" sticker and a "B" sticker.
I'll also clue you in on the bastard hold that you run the wire through the firewall. Start at the throttle body, and go straight back to the firewall, then go straight down to the very bottom and you should see a small circular hard plastic cover (it's about 1 inch in diameter). Pop that bitch out and it'll lead to a hole right above and to the left of the ECU compartment.
Old Apr 12, 2008 | 11:21 PM
AP96's Avatar
Yeah I bought them new.
How long did it take you to install your OEM ones?
Old Apr 13, 2008 | 06:46 AM
Well I had done 2 DEPO installs prior , and I actually did the install without the instructions and guessed where it went. I would say hour and a half to get all that done, then I took apart my fogs and put yellow lamin-x on them.
Old Apr 13, 2008 | 06:52 AM
AP96's Avatar
Ah nice, hopefully these don't take me too long. I'm actually about to start on this.
I dunno if I should paint the lenses on these, I'm still debating.
Old Apr 13, 2008 | 08:10 AM
Go Lamin-X with them, I did that and you can't tell if they're yellow OEM or not. It's a perfect match.
Old Apr 13, 2008 | 08:49 AM
AP96's Avatar
Alright, I'm about to start on them. Pics when I'm done
Old Apr 13, 2008 | 01:55 PM
AP96's Avatar
MuffinMan, I have everything wired up I just can't pop the grommet out that's on the firewall. How did you get it out?
Old Apr 13, 2008 | 02:01 PM
pull up the ECU metal covering, there will be a preforated circle in the sound padding there, pull that out from the inside, then poke the plastic out
Old Apr 13, 2008 | 02:09 PM
oem_certified_accord's Avatar
Default Re: (TheMuffinMan)
^ lamin-x is a "lamination" type material as opposed to painting the lenses with model car paint, correct?
Old Apr 13, 2008 | 03:01 PM
it's a clear sticker basically
Old Apr 13, 2008 | 03:12 PM
AP96's Avatar
Wow lost here, there's a two prong plug in (male) and there's one that looks like the male would plag into, what do those go into? That has got me stumped. I looked over the instructions four times and don't get it still.
Old Apr 13, 2008 | 03:16 PM
That stretches to the driver's side corner light.
Car harness > Fog harness > corner light
Old Apr 13, 2008 | 03:23 PM
AP96's Avatar
Both of them? So unplug the wire from the corner light then run the wires all in series then plug back into corner light?
Lol I dunno how I'd be doing this without your help, Million thanks to you MuffinMan.
Old Apr 13, 2008 | 03:27 PM
Yeah it's in series, they'll only fit on one of the 2 plugs, one is flat on the sides and the other has a raised bump thing.
So plug in the one from the car into the fog harness, and use the other fog harness one to the corner light
Ghetto, but what you want to do
Modified by TheMuffinMan at 7:34 PM 4/13/2008
