f23 intake manifold on f22b1 head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hammer99ex »</TD></TR><TR><TD CLASS="quote">they dont line up, better off keeping ur stock mani and porting it out</TD></TR></TABLE>
what? wrong... You sure you're not think H23, which in that case still lines up but ports are different shape.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord_creeper »</TD></TR><TR><TD CLASS="quote">i picked up a f23 intake manifold and i was wondering if theres an serious mods that need to be done??</TD></TR></TABLE>
They do line up and no, to my knowledge there isn't any serious mods that need to be done for it to go onto that head.
Just wondering what your reasoning is for swapping the F23 IM? And in what areas are you planing to gain by swapping them? Is it fuel economy, power or just a cheap replacement for a broken part?
I'm not familiar with the F23's specs. do they have a shorter/longer runner, larger/smaller plenum or larger/smaller Throttle body?
Just trying to broden my horizons is all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord_creeper »</TD></TR><TR><TD CLASS="quote">thanks and yes the h23 manifold u have to drill a bolt whole or somthing to that sort. thanks for the info
no, you don't have to drill any holes but you do have to remove some material from the mounting flange for the VTEC solenoid. Then the ports need some work, etc.
</TD></TR></TABLE>no, you don't have to drill any holes but you do have to remove some material from the mounting flange for the VTEC solenoid. Then the ports need some work, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord »</TD></TR><TR><TD CLASS="quote">Just wondering what your reasoning is for swapping the F23 IM? And in what areas are you planing to gain by swapping them? Is it fuel economy, power or just a cheap replacement for a broken part?
I don't recall if the runners are shorter or longer but the plenum is larger on the F23 intake manifold. I believe the throttle bodies are the same size but don't quote me on that.
</TD></TR></TABLE>I don't recall if the runners are shorter or longer but the plenum is larger on the F23 intake manifold. I believe the throttle bodies are the same size but don't quote me on that.
i want to know to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">I don't recall if the runners are shorter or longer but the plenum is larger on the F23 intake manifold. I believe the throttle bodies are the same size but don't quote me on that.</TD></TR></TABLE>
can anyone back this up?
</TD></TR></TABLE>i want to know to
well i got a 60mm prelude throttle body for the f23 manifold and yes the plenum and runners are bigger than that of a f22b1. i took them apart to compare. but now i got other problems i dunno if i gotta make a new thread but if i do dont flame me im a noob lmao. i tried putting the 60mm prelude throttle body on my f22b1 and now the dam car sounds like a subaru lmao any ideas?
Your going to have to port the F23 plenum to match the 60mm throttle body. If you look in the mouth of the throttle body with the butterfly open you will probably see a 3mm step/seam between the TB & plenum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS-2 »</TD></TR><TR><TD CLASS="quote">can anyone back this up? </TD></TR></TABLE>
let me try and find the thread with that info. I remember doing a bunch of searching years ago when I was going to be putting the H23 IM onto my F22B1.
yes i did dremmel that lip on there it wasnt that bad to do and i ported out the f22b1 upper cannister after the throttle body to almost similar to the same design as the f23
here you go...
http://www.accordinglydone.com...23+IM
pictures don't work but if you read it it states the F23 runners are shorter, the F23 ports are slightly larger and the F23 plenum is larger.
no way ... i have a a beast 94 coupe with f22b1 . i have dc headers . intake .. magnaflow exhaust .. 4 wheels discs .. h@r super sports .. etc ... but i have been reading up about throttle bodys .. and i thought ide look into this ... i was going to buy a skunk 2 . 70 mm.. throttle body .. . or itlease . something bigger then stock which i beleive is 55mm .. i took my tb off today and its filthy. and i also cleaned the intake manifold as much as possible .. im wondering how nasty it would be of an increase with the 70 mm tb .. and maybe even .. bore the stock manifold if its neccesssary .. im def interested!
i would say thats a goodd thing it sounds like a subaru.. does it run better though... the f22b1 has 147 trq stock and with minor .. /mild work .. it can be a nasty little n.a ... a good intake . exhaust.. header. (* throttle body should do a nice bit
The F22B1 in NA trim is never going to be truly "nasty" until you open up the block and increase the bore/compression. You can bolt parts onto these engines til the cows come home. But it will only get you so far.
