exhaust question...
Old Apr 12, 2008 | 04:28 PM
NotAdelslow's Avatar
Default exhaust question...
so i searched for this thread and found it no where, unless you guys can some how link me to one. I have a 95 civic with a gsr. It's getting ready for boost but i want to make it look like a sleeper. i noticed that alot of gsr's out there look like they have a stock exhaust on. i wanted to go with that look of the gsr muffler. my question is not the gsr muffler but the gsr resonator pipe. should it fit perfectly just fine? the rest of the exhaust is being custom built, but i just want to use less piping as much as possible.
i'm hoping for the resonator pipe to fit to the cat, the mid pipe with be welded to the resonator pipe and the muffler. so yeah should it fit? or am i on crack and this is a stupid idea....?
Old Apr 12, 2008 | 04:55 PM
Default Re: exhaust question... (NotAdelslow)
bump
Old Apr 12, 2008 | 06:37 PM
ejprimo's Avatar
it sounds like you want to reuse the stock piping and resonator and just add a muffler? if youre going to boost then you would probably want at least a 2.5in diameter piping. the gsr resonator is around 2in in diameter so reusing it wouldnt make sense.
since you already have a gsr motor, id suggest you get a 2.5in diameter magnaflow resonator part #10436. if you want to save money go to amazon.com and type in "magnaflow 10436" and click on the first link. be sure to click on free super saving shipping and plus no tax, so out the door it will $68.40. if you do the same for a 2.5in diameter magnaflow cat and a magnaflow muffler, then youll have all three for around $200 with no tax and free shipping. All that you will have to worry about is whether you want mandrel or crush bent piping and which muffler shop is going to install it. for crush bent it shouldnt cost more than $100-120 to install.
Old Apr 12, 2008 | 07:25 PM
d.a ryda's Avatar
Default Re: exhaust question... (ejprimo)
put a muffler that looks stock
Old Apr 12, 2008 | 07:28 PM
spock_rocker's Avatar
memoryFAB.com representative
http://www.kteller.biz they have stock like exhaust for turbo applications..its worth looking into
Old Apr 12, 2008 | 08:43 PM
should the resonator pipe fit anyways? and then all i had to do is custom bend the mid pipe and part of the axle back?
Old Apr 12, 2008 | 09:30 PM
lilo_goki's Avatar
it seems like you just want a stock axle back for ur civic so it'll look like a sleeper. your not gonna want the stock resonator pipe, just get urself a aftermarket exhaust system with the resonator pipe and u can just get a stock integra axle back and have the muffler shop custom it to fit ur aftermarket pipping.
Nautical_Star
Aug 5, 2008 12:18 PM
b18c-1
Aug 17, 2005 02:58 PM
dacaveman
Nov 23, 2004 03:43 PM
DA KING
Nov 20, 2004 05:21 PM
GReddy212
Oct 22, 2004 07:06 PM
