1994 Honda Accord LX-overheats
My accord overheats while I'm sitting in one place, while driving it is fine. So first, we assumed it was the radiator fan and made sure that the motor and any fuses connected to it were working. Then we replaced the radiator cooling fan switch. Finally, we replaced the thermostat and it still overheats. Now, the fan works when the car is off, but will not turn on when needed at say a stoplight.
Anybody have any ideas?????
This link has a wealth of information about overheating. Maybe you can find the cause there. My vote is for<U> fan timer</U>, but you should read for yourself. Good Luck!
http://techauto.awardspace.com/overheating.html
hi
i just want to tell you to look at the temperature sensor or the sensor that control the cooling fan there is a sensor that control the cooling fan check that....
bye
bye
