anyone using a vacum canister or vac. pump?
Old Apr 12, 2008 | 02:40 PM
h22 civic's Avatar
Default anyone using a vacum canister or vac. pump?
anyone ??
Old Apr 12, 2008 | 06:55 PM
DaveF's Avatar
Default Re: anyone using a vacum canister or vac. pump? (h22 civic)
they arent worth a **** on our hotrod cars. the engine makes so much crankcase pressure it pops the relief valve in the vacum system, and then shoots oil all over the place(firewall/engine/pops the dipstick out) the car has come back from a run with the oil dripping off the wheelie bar. (this was back in 05/06)
we have switched to venting the engine on the front side of the valvecover with large diameter vent tubes and havent had the same problem since.
Old Apr 13, 2008 | 07:01 AM
h22 civic's Avatar
Default Re: anyone using a vacum canister or vac. pump? (DaveF)
im more concerned about brakes ,idleing,etc with big cams ..i know you could build a vacum wall in the map but was figuring just put a canister or pump and be done with it ...where you running a canister or pump at the time ?
Old Apr 13, 2008 | 01:05 PM
DaveF's Avatar
we are talking about 2 differant things. and honestly, adding or subtracting numbers on a chart would be much easier than setting up whatever it is you are thinking of.
Old Apr 13, 2008 | 03:41 PM
h22 civic's Avatar
lol.....yea im talking about this
http://www.jegs.com/webapp/wcs...lue=1
and this http://www.jegs.com/webapp/wcs...lue=1
Mr. Future
Nov 22, 2015 07:46 PM
GI8U2racing
14
Nov 12, 2007 09:04 AM
LordAphotic
Apr 12, 2006 11:32 AM
00specR
Nov 15, 2005 04:55 PM
