Help with B18c in 91 teg
I am new to the honda world and just bought a 91 teg with a 96 gsr motor. It does not have ac, has anybody put ac back on after this swap? which compressor should I use? Any help would be appreciated. Also how do I know which wiring these guys went with as far as obdo or obd1. Thanks, James
a compressor off a gsr will work, i actually have one if you need one. Im guessing there would be a conversion harness down by the ecu if they did it correctly. obd0 to obd1 with an obd1 ecu maybe?
b series compressor will work. If there is no conversion (obd0 to obd1) just buy a obd0 vtec ecu, sk2 im, stock wiring harness and run the plugs to the pins. Magical and easy
