T517z rebuild but looks like a t-28
Old Apr 12, 2008 | 11:37 AM
moores55's Avatar
Default T517z rebuild but looks like a t-28
ok, So I have the greddy kit for my ep3 and my turbo (T517z) is in need of a rebuild. I called greddy and they told me that they no longer sell rebuild kits and told me i would have to send it to them and then they would send it to japan to be rebuilt. That wont work for me so the next question i had was, what rebuild kit can i buy that will be the same for the t517z? They could not tell me. Next I called gopopshop.com and asked them, I gave them the number off my turbo and they told me it looks like a td05 rebuild kit will work and is the same. The question that i have is this. My turbo (t517z) exhaust housing dose not look like that of a td05, it has a t-28 exhaust housing. Even though the housings are diffrent can my turbo still be rebuilt with a td05 rebuild kit? Here is what my turbo exhaust side looks like
and here is a td05
There seems to be no info on the t517z and i'm really at a stand still about what to do about a rebuild or replacement.
Modified by moores55 at 12:46 PM 4/12/2008
Old Apr 12, 2008 | 11:58 AM
mrbsponge's Avatar
Yeah it seems Greddy likes to hide the info on this and the t518z from the s2k kit. Really from what i have seen its nothing more than a modified 18G and close to a 20G, i would personally ditch that turbo and get something a lil bigger as the power from them is horrible. i did an EP3 with a cybernation kit and got 311 on a stock map sensor with hondata.
did an EP3 with a greddy kit, 268 at 15psi with a 3 bar
Old Apr 12, 2008 | 12:05 PM
moores55's Avatar
Default Re: (mrbsponge)
Problem is i can't fit anything bigger with the greddy manifold. I would need a treadstone or revhard mani to get somthing bigger in there. I have been tuned and don't have the cash for a retune with a bigger turbo. I just can't find any info about rebuild kits for this damn thing. It looks like if i bought a new t28 it would bolt right up.
Old Apr 12, 2008 | 02:03 PM
moores55's Avatar
Default Re: (moores55)
ttt
Old Apr 12, 2008 | 02:59 PM
tokesGTR's Avatar
The greddy t518z is a TD05h-18G turbo with a T25 flange/exhaust housing, from what I have seen. Since the 517 is a bit smaller I would assume an 18G rebuild kit would work.
Try this site, http://www.gtr.co.uk, as Greddy sells a t518Z kit for GTR's and is a decently common upgrade to the stock twins, they might have a bit more info. Hope this helps somewhat
Old Apr 15, 2008 | 05:19 PM
TheShodan's Avatar
Moderator
The greddy turbochargers used are Mitsu/Garrett hybrid turbochargers. They use a mitsubishi compressor wheel, and cartrdige. The turbine housing is Garrett, as is the exhaust wheel (in some models) a Mitsubishi turbo rebuild center will be able to fix the turbo.
Old Apr 16, 2008 | 11:25 AM
moores55's Avatar
Default Re: (TheShodan)
Thanks, I ordered a td05/h rebuild kit so i hope that fixes it.
bluemax189
Mar 17, 2006 05:48 PM
ATS*Mark
Mar 5, 2004 07:13 AM
jarel
Aug 2, 2002 02:17 PM
racer4200
Sep 7, 2001 04:58 AM
