Piston Slap and Rebuild?
Old Apr 12, 2008 | 09:07 AM
UncivilB18C's Avatar
Default Piston Slap and Rebuild?
Ok, I rebuilt my ls about 8 months ago due to all 4 ringlands cracking. Failure in the fuel system. lawl.
Motor's making a funny knock from about 3k-3300. I'ts not rod bearings. Thinking piston slap. Can I use stock bore 81mm pistons on new rebuild? I've got a set of low compression nippon pistons, just not sure if it will fix the problem.
Old Apr 12, 2008 | 09:11 AM
Default Re: Piston Slap and Rebuild? (UncivilB18C)
Never mind. I found the search in the corner.
Old Apr 12, 2008 | 09:23 AM
civicstar's Avatar
your better off going oversized pistons to make sure those cylinders are clear and get it honed
deanobob123
Apr 9, 2018 12:16 PM
JDM-EJ698
Apr 23, 2009 06:29 PM
siis2fast
Jun 7, 2005 03:52 AM
gaskleppie
Apr 14, 2004 09:34 AM
ek
Jun 10, 2002 08:52 AM
