New converstion Harness, Fuel pump wont shut off, Floods with fuel !!! HELP!!!
Hey
I have a 97 del sol with a b16 swap I recently had to change the conversion harness because of the ghetto way **** was wired, Wires were falling out of place. I got a new ob2a to obd1 harness, the only wires I spliced in were the Vtec Pressure sensor, vtec solenoid, and Iacv. Now my car won't start, Since the fuel pump won't shut off when key turned to accessory, motor floods with fuel. I have tested main relay, everything tests out ok...possible wiring or ecu problem.....? I need some help. THanks
please help
Thanks!!
Modified by bigizsosexy at 9:25 AM 4/14/2008
please help
Thanks!!
bigizsosexy
Apr 23, 2008 11:14 AM
primeredsol
14
Dec 21, 2006 10:57 PM
integrator43
Mar 13, 2005 09:14 AM
