Will Hondata S300 work with JDM P72 ECU???
Old Apr 12, 2008 | 07:42 AM
oneprelude's Avatar
Default Will Hondata S300 work with JDM P72 ECU???
The reason for the question is because I heard that JDM ECUs have their own codes. Thanks for the help
Old Apr 12, 2008 | 07:30 PM
Jaker's Avatar
Default Re: Will Hondata S300 work with JDM P72 ECU??? (oneprelude)
The S300 does not care if its a JDM or a USDM ECU. They'll both work. The problem is fitting the S300 inside the case. Hondata has a version of the S300 specific for the JDM ECUs. You could probably get the S300 meant for the USDM ECUs to work with the JDM ECU if you made up an adapter harness and figured out a way to mount the S300 circuit board somewhere safe.
Green Lude 93
Engine Management and Tuning
Oct 10, 2010 06:23 PM
Gr33nBBean
Sep 29, 2008 07:03 AM
Euro98ITR
Jun 15, 2008 02:30 PM
civtegra_hybrid
Jan 7, 2005 09:29 AM
