Where do these vacume lines go???
Old Jul 11, 2002 | 07:42 AM
fire7882's Avatar
Default Where do these vacume lines go???
Where does the vacume line go that comes from fuel pressure regulator(or where can i tie in to work properly)?
Where does the vacume line go with the one way valve that is coming off the diaphragm mounted on the Throttle body(or where can i tie in to work properly)?
First gen b16a in a 5g ex civic
[Modified by fire7882, 1:08 PM 7/11/2002]
Old Jul 11, 2002 | 07:44 AM
Malachi's Avatar
Default Re: Where do these vacume lines go??? (fire7882)
Old Jul 11, 2002 | 03:09 PM
fire7882's Avatar
Please!!! Someone must know.
Old Jul 11, 2002 | 10:41 PM
salbaje's Avatar
what car is this on??
Old Jul 12, 2002 | 01:37 AM
kinesistech's Avatar
Not that it matters but he mentioned the car.
Run the vaccum line for the fuel reg. to the manifold. It just needs manifold vaccum no check valves or anything on it. The other is useless. Irs for the dashpot that you dont use either. Clean that engine up and remove all that ****. You dont need the metal lines on the back of the manifold either. All you do need are the 2 on the TB for MAP and charcol canister, fuel reg vaccum source, evap. purge solenoid (which I would also mount), and PCV which is good.
Old Jul 12, 2002 | 07:43 AM
fire7882's Avatar
Default Re: Where do these vacume lines go??? (kinesistech)
Thanks alot for the help!!! I mounted the purge solenoid last night and i was planning on cleaning everything up once i get everything running right. So you are saying that i can just remove the entire dashpot off the TB because it is useless, right???
Old Jul 12, 2002 | 01:09 PM
Yep, if it leaves a hole be sure to plug it.
CorrodeONE
Jun 27, 2008 05:49 PM
B16A CRX
Mar 20, 2008 04:53 PM
TehMan
Mar 20, 2006 12:49 PM
4G-CIVIC
Nov 3, 2001 08:20 AM
