B17 ARP rod bolts?
Old Jul 11, 2002 | 06:58 AM
NC-B17A's Avatar
Default B17 ARP rod bolts?
I had to have my factory rods shotpeened. Anyway does anyone know which ARP rod bolts will fit the oem B17 rods?
Here are the 2 part #s from Summitracing.
ARP-208-6001 Honda: 1.2L/1.6L, 8mm diameter, high performance, connecting rod bolts ...
ARP-208-6401 Honda: 1.8L, 9 mm shank, Pro Series Wave-Loc, rod bolt kit Rod Bolts C-head PRO Wave-Loc Honda 1.8L 9mm
Old Jul 11, 2002 | 07:19 AM
Speed PHreak's Avatar
Default Re: B17 ARP rod bolts? (NC-B17A)
I'd venture a guess that there' the ARP-208-6001's. The B17 is just a stroked B16.
Just FYI the 208-6401's are for the GS-R/ITR 1.8L, I had to use the 208-6001's on my LS.
[Modified by Speed PHreak, 4:20 PM 7/11/2002]
Old Jul 11, 2002 | 03:57 PM
Rocket's Avatar
It's the 208-6401. I know because I have these in stock and have measured the rod bolts.
[Modified by Rocket, 12:58 AM 7/12/2002]
Old Jul 11, 2002 | 03:59 PM
Rocket's Avatar
Default Re: B17 ARP rod bolts? (Rocket)
You should have the rods properly machined to accept the larger under head radius of these bolts.
They are good insurance if you have to run stock rods as the higher clamping force of the bolts allow them to be abused more with more reliability.
[Modified by Rocket, 12:59 AM 7/12/2002]
Old Jul 11, 2002 | 06:43 PM
NC-B17A's Avatar
So if I use these then I have more machine work to do?
Old Jul 12, 2002 | 05:33 AM
My mistake, thanx for the correct info Rocket!
Old Jul 12, 2002 | 10:36 AM
Rocket's Avatar
Default Re: B17 ARP rod bolts? (Speed PHreak)
No worries, ARP doesn't have very accurate application listings.
Old Jul 12, 2002 | 10:37 AM
Rocket's Avatar
If you have a cool machine guy it shouldn't cost much. Otherwise you will be localizing stress on the radius of the headbolt and that can't be good.
[Modified by Rocket, 7:37 PM 7/12/2002]
Old Jul 12, 2002 | 12:55 PM
vhd's Avatar
vhd
yeah the big end of the rod may also have to be resized when using the arp rod bolts. because the new rod bolts will create more bearing crush cause they are torqued more then the stock bolts. so when you a have the machine shop do it for you, ask them to check if the big end is still round and/or needs to be grind and rehone. oh i got a set of the arp 208-6401 9mm rod bolt set if you interested, its still new, just bought the wrong ones for my ls
Propulsion
Mar 18, 2006 06:09 PM
neyrod
Feb 16, 2005 11:05 AM
scUba-stEve
Aug 13, 2004 03:40 PM
turbociv
Sep 8, 2003 05:41 AM
Drag R
Jun 14, 2003 07:54 AM
