Tire temp fluctuations
An interesting topic/question came up in another group I am with. I wanted to ask the question here since I think the answers will be better.
How much is the temperature fluctuation of a "warmed up" race tire during a lap? Once the tire is "warmed up", there will still be temp fluctuations due to cornering, braking, and acceleration differences around the track. What I am curious about is the absolute magnitude of these variations. My guess is the fluctuations are not that large, but I do not have the logging to have any data to back this up. If anyone does, I would appreciatte any numbers that you could give. Thanks.
I have seen real time tire temp traces with differences of 20-40F between inside and outside for open-wheel race cars. I would think on production cars, the delta could be greater with race tires. A bit less so with street tires.
My temperature variance is about 10°F degrees upfront which ideally (according to Matt Bell), they should be roughly ~25°F. This means I need more camber which is okay because I felt this time around the car pushes.
For the rear tires, my variance is ~4°F. What are you all running? I like a happy tail end and right now I am at -2.0°camber in the rear. Any more would kill it.
Here are some data logs of the 3 tire temps on each of two tires for an oval racing car at two different pointson a lap. They give an idea of the range around a lap, and shows you that taking temps in the pits tells you little about on track temps. Curious to see the reversals, and thewidening and narrowing of the range between parts..
bubbajim
Mar 3, 2003 05:59 PM
GEN2 HYBRID
Jan 2, 2002 06:48 PM
