Suspension & Brakes Theory, alignment, spring rates....
T1R B-MAX Coilovers
Old Apr 11, 2008 | 03:07 PM
FFerio's Avatar
Default T1R B-MAX Coilovers
like the topic says. i got the t1r bmax coilover setup for itr applications on my EG.
this is the first set of damper adjustable coilovers i've ever owned. question is. the **** on top has numbers 1-4 and u can twist it for days and on the aj racing website it says it's 36 way adjustable.
how do i know where i'm at when i'm turning it. doesn't make sense to me at all. i'm trying to make the things as stiff as possible that's all.
Old Apr 13, 2008 | 04:40 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: T1R B-MAX Coilovers (FFerio)
There are probably no pre-set "clicks" so you just have to keep track of how many times you turn it. If you want it stiffest, set it to full soft, then turn it 360* 9 times. I'm basing that off their "36-way adjustability" (36/4 = 9). Often when a shock manufacturer says "24-way," "36-way," or "108-way" it means there are really an infinite number of ways to adjust the shock because there are no detents, or clicks.
Old Apr 13, 2008 | 03:28 PM
I makes it RAIN's Avatar
Default Re: T1R B-MAX Coilovers (Stinkycheezmonky)
Turn it till your guts bleed.
Old Apr 14, 2008 | 10:08 PM
FFerio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stinkycheezmonky &raquo;</TD></TR><TR><TD CLASS="quote">There are probably no pre-set "clicks" so you just have to keep track of how many times you turn it. If you want it stiffest, set it to full soft, then turn it 360* 9 times. I'm basing that off their "36-way adjustability" (36/4 = 9). Often when a shock manufacturer says "24-way," "36-way," or "108-way" it means there are really an infinite number of ways to adjust the shock because there are no detents, or clicks.</TD></TR></TABLE>
it clicks. jus never ending..so i don't know if i'm at the beginning or at the end. or maybe i haven't even twisted it till the end yet lol. ima try that tomorrow morning. thanks man.
Old Apr 15, 2008 | 03:31 AM
Suspetise...
If it does click, turn it to full soft first. Turning it past full hard can hurt the shock, but turning to full soft should "stop". You should feel a very significant difference in how hard it is to turn the ****, if you can turn it at all.
jst2878
Suspension & Brakes
11
Apr 6, 2012 02:50 PM
pinks11
Suspension & Brakes
Dec 26, 2008 03:59 AM
boraVr
Suspension & Brakes
Oct 25, 2007 11:26 AM
West Coast EG6
Suspension & Brakes
Apr 10, 2006 08:49 AM
chet
Dec 6, 2002 12:28 PM
