Throwing code 9
i hear this code doesnt happen too often. i know what code 9 is. i just need to know how to fix it. any recommendations?
Modified by JDMatt3 at 11:23 AM 4/11/2008
what motor do u have??code 9 is for the cyl. postion sensor.here look in this link.
https://honda-tech.com/zerothread/1710584
what distributor do you have? - you need the Si or HF distributor with the MPFI - the DX distributor won't work - if you have the Si or HF distributor and are getting code 9, then you most likely need a different distributor or you have a problem in the wiring
replace the distributor. if the problem is still there. open up your ecu and check to see if anything looks fried. it happened to me. i changed the distributor and it kept on throwing code 9. checked the ecu it was fried changed it and the problem went away.
psycho.chicken
Jul 21, 2006 09:34 AM
ScottEK
10
Oct 23, 2002 03:09 PM
