New to integra
Hi guys,
Im a new integra owner, just got my GSR yesterday off of a dealer. My car is white with gray interior. So far the car is all stock with some minor problems. One of the headlights is blown and both tend to get moisture inside when its wet outside, i think the seals are just going bad. The steering wheel box/hub thing has no screws so its really loose, and the Stereo system is loose because of broken tabs. Lastly the motor in the windows are dying i think because the windows are slow, and someone chopped the antenna and stole my ACURA badge
So all I really care now is i need a 1997 Acura Integra Owners Manual for a gsr. So i was wondering if you guys could help me get one. Also I was wondering how to replace a headlight bulb. Thanks for the help.
.So all I really care now is i need a 1997 Acura Integra Owners Manual for a gsr. So i was wondering if you guys could help me get one. Also I was wondering how to replace a headlight bulb. Thanks for the help.
Dogginator has it. It can be found at this link here, I believe: http://www.hondahookup.com/manuals/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UmbraDc2K »</TD></TR><TR><TD CLASS="quote">Dogginator has it. It can be found at this link here, I believe: http://www.hondahookup.com/manuals/</TD></TR></TABLE>
heh. All hail Dogginator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickdrizzle »</TD></TR><TR><TD CLASS="quote">
heh. All hail Dogginator.</TD></TR></TABLE>
lol
lol
Well first welcome to the Integra club lol. You might want to make sure that they slides for the windows are not full of crud. Maybe spray some lube down the slides to see if it helps.
^ werd.
Spray some silicone spray down the tracks and let it sit. In 24 hrs or so they will be golden. Your headlight issue could be a cracked lens or a seal, just have to look into it. And as far as your interior troubles, you'll just have to pull it apart and investigate whats missing
Good Luck and welcome
