Minor problem... maybe?
Old Apr 11, 2008 | 07:27 AM
civic90's Avatar
Default Engine not shutting down completely...
ok here is the scoop... i have the 90 hatch dx b16a swap in. my friend and i use butt-connectors(lol) to wire the engine up. anyway engine runs fine no code whatsoever. i went back and solder every wire we butted " 1 at a time ". so i doubt i got any wire crossed up. anyway got it finish... starts no code but when i turn the car off engine stays on. i'm able to pull the key off the ignition and engine stays on ... any suggestion would be appreciated.
Edit: ok i done some more test... thinkin it was the ignition housing... so i turn the car on with the use of a flat head on the ignition switch. everything fired up fine. but again at off switch still the cars engine running. but when i let the car die but lettin it catch in gear even with no power to radio no key in the ignition... i hear noise comin out the injectors or i'm thinking its the injectors. its like i'm gettin constant power to whatever keeps the cars engine running... i tried eveything. so i'm thinking on just installing a kill switch to the grounds main relay to kill the car. help me out if you can please....
Modified by civic90 at 10:08 AM 4/14/2008
Modified by civic90 at 10:10 AM 4/14/2008
Old Apr 11, 2008 | 01:48 PM
civic90's Avatar
Default Re: Minor problem... maybe? (civic90)
bump...
Old Apr 14, 2008 | 09:11 AM
civic90's Avatar
Default Re: Engine not shutting down completely... (civic90)
bump again.. help
Old Apr 15, 2008 | 01:15 AM
bryse68's Avatar
sorry, your up sh*ts creek without a paddle one this one.
Old Apr 16, 2008 | 04:27 AM
civic90's Avatar
again... done some more test. took a light probe to each wire on the main relay. at "on" position all the wire lit up except for ground of course without cranking the car. i unplug the yellow/white stripe wire. start the car up... everything good. i then turn the car off everything shutdown like normal. seems like this yellow/white stripe wire is keepin my runnin if plug up when the ignition is at "off" position. what is this yellow/white stripe wire? anyone help me out thx.
Old Apr 16, 2008 | 04:47 AM
kirbyman's Avatar
what does this yellow/white stripe wire come from?
edit: okay, so i happened to be looking through the Haynes manual(awesome thing to have around. they actually have useful information in em.. like wiring diagrams..) and i looked at the main relay, it has a Y/W wire coming out of it which heads to a 15a fuse for the ecu, then turns into a white wire, heads to a 45a fuse, then a 55a fuse, then to the battery.
Modified by kirbyman at 8:55 AM 4/16/2008
Old Apr 22, 2008 | 04:09 AM
civic90's Avatar
Default Re: Engine not shutting down completely... (kirbyman)
thanx for the info kirbyman... oh btw looked at your garage sell. b series shift linkage which brand, hasport or avid?
Old Apr 22, 2008 | 05:29 AM
kirbyman's Avatar
unfortunately neither.. but still very strong looking indeed..
dwerpk
Dec 25, 2006 11:37 AM
B20inDCinLBC
Sep 21, 2006 07:11 PM
nbcivic
Feb 1, 2006 02:59 PM
ActiveAero
Sep 27, 2004 10:33 AM
