y8 intake manifold conversion
Old Apr 10, 2008 | 11:13 PM
4dek's Avatar
Default y8 intake manifold conversion
just did a y8 intake mani swap on my 97 civic lx (d16y7) but now having problems hooking up the hoses. is there any diagram or illustration of where all these hoses go?pls help
Old Apr 12, 2008 | 01:29 AM
Legion's Avatar
* B A N N E D *
Default Re: y8 intake manifold conversion (4dek)
1. This is the nipple on your intake manifold (right off the head flange). Connect it to the closest throttle body nipple (2).
3. Connect this nipple to your IAC valve (which is attached to the back of the manifold)
5. Connect this nipple back to the nipple on your main water pipe (6).
7. Connect this huge nipple on the thermostat housing to the huge nipple on your intake manifold. This will actually be pretty easy to figure out – you just take that huge u-bend of heater hose and connect the only two huge nipples together.
So basically, the coolant flows out of the water pipe (6), flows through the EACV, then flows over through the throttle body, and finally flows back into the manifold (1). The second coolant route is where coolant comes flowing out of the block and through the manifold (7) then flows into the thermostat housing (8).
thebleek
Sep 4, 2008 01:43 PM
suspendedHatch
Sep 18, 2006 05:00 PM
MBlake55
10
Apr 4, 2006 06:43 PM
redsled00
15
Jan 20, 2005 04:39 PM
