help !!! need help and suggestions with headgasket install
Old Jul 11, 2002 | 03:07 AM
gregcivic92lx's Avatar
New User
Default help !!! need help and suggestions with headgasket install
if it helps it's a d15b7 motor
Old Jul 11, 2002 | 07:12 PM
whatVTEC's Avatar
Default Re: help !!! need help and suggestions with headgasket install (gregcivic89dx)
what do you need to know?
Old Jul 11, 2002 | 08:37 PM
Steve91's Avatar
Suggestions? Have your head resurfaced by a machine shop. Replace the gasket with one from a 96-00 civic ex. Is metal and much stronger
Old Jul 11, 2002 | 08:43 PM
Kamin's Avatar
Default Re: help !!! need help and suggestions with headgasket install (Steve91)
oook
i dont know bore sizes or head diffrences but im 99% sure a headgasket from a vtec motor and a 1.6l motor, wont work on a nonvtec 1.5l motor.
go buy a helms.
dont attempt this if you dont know what your doing.
Old Jul 11, 2002 | 09:06 PM
builthatch's Avatar
MiG-21 superfan
if you are not using studs, watch out for the dowels, they will scratch the head/block mating surface(s) IF YOU ARE NOT CAREFUL WHEN PUTTING THE HEAD ON THE BLOCK...also, pick up some Hylomar made by permatex and spray both sides of the gasket, let it set for 5 mins then install...
[Modified by builthatch, 1:07 AM 7/12/2002]
BryanChunkMcC
Feb 28, 2014 03:26 AM
jhendry
Feb 15, 2011 05:20 PM
Vintech
Apr 10, 2006 10:04 AM
Vintech
Apr 10, 2006 07:38 AM
