88 si tranny question.
alright quick question. Im dropping a d15b7 into a 91 si, i've converted the dizzy to obd1, and have the ecu conversion harness to obd1 as well. The tranny i picked up is an 88 si out of a CRX. From what ive read i can only use the 88 clutch kit which is fine, but will any d-series flywheel work?! This is the only thing im not sure on.
hha what up bro. Not sure. havnt seen the condition of mine considering there 100s of parts on them right now. Hit me up on AIM ive got some pics of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1_Sleeper »</TD></TR><TR><TD CLASS="quote">hha what up bro. Not sure. havnt seen the condition of mine considering there 100s of parts on them right now. Hit me up on AIM ive got some pics of it.</TD></TR></TABLE>
no im asking if youd want to buy mine.
Mint . . well just a bit of fade on the tops but not noticable.
give me your email and ill send you pics when i get home from workk
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1_Sleeper »</TD></TR><TR><TD CLASS="quote"> From what ive read i can only use the 88 clutch kit which is fine, but will any d-series flywheel work?! This is the only thing im not sure on. </TD></TR></TABLE>if you use the 88 clutch kit, you need 88-89 flywheel - 90 and up flywheels are for 212mm diameter clutch where 88-89 flywheels are for 200mm diameter clutch - 88-89 pressure plate will not bolt to 90 and up flywheels - different bolt circle
firstgenrex
Jan 25, 2004 10:23 AM
