actually fit a 4 dr?
in the picture of the exhaust, it says it will fit both 2 dr and 4 dr; i thought the 4 dr was different. other companies have different exhausts for 2 and 4 dr. question is, will it fit?
It looks like in the bottom-right of the picture it has a ~2 inch clamp, much like vibrant uses. If that's the case, you can extend the exhaust enough to fit a sedan and then clamp it tightly.
From what is shown in that picture, that exhaust will only fit the Coupe. But, you could just go to a muffler shop and have them make you the extension that would make it fit the Sedan.
That being said; that exhaust is probably going to do more bad for your engine than good. If you are just getting it for sound, buy the fart can from PepBoys and save the money. It is not JDM, no matter what the headline says.
i'm just looking for a cheap exhaust before i save up and get skunk2 catback, so i probably shouldnt get that at all, just wait to get skunk2?
just save up for the exhaust you want,going cheap is not worth it. also 2 door and 4 door exhaust systems aren't the same so if the seller is claiming it fits both models, its some cheap knock off.
try it out you never know, alot of these parts come from the same factory as the JDM stuff.
reminds me of the ebay s2k header, everyone talked crap till someone dyno'd and proved it made power, not only that it had the same shipping address as the Megan racing company.
95TEG
May 27, 2009 03:54 PM
