b20 swap
Old Apr 10, 2008 | 04:22 PM
slo_ej8's Avatar
Default b20 swap
can i use my stock 00 civic harness with the swap? thanks
Old Apr 10, 2008 | 04:25 PM
nicks-eg6's Avatar
Default Re: b20 swap (slo_ej8)
if the motor is obd2....yes, if it was made 96+ you can
Old Apr 10, 2008 | 04:42 PM
91 ef hatchback's Avatar
Default Re: b20 swap (nicks-eg6)
when you do the swap make sure you use a different manifold then the stock b20 manifold it is to tall to fit... you can use and ls manifold its the same bolt pattern and will clear the hood
slo_ej8's Avatar
yeah sorry, its a b20z. which is obd2. so everything will plug up except a few for vtec correct? its a straight b20z swap.
Old Apr 10, 2008 | 04:43 PM
Default Re: b20 swap (91 ef hatchback)
correct just make sure you use a non-vtec computer or it will not run right
Old Apr 10, 2008 | 04:44 PM
slo_ej8's Avatar
yeah, i got the ls manifold and obd1 p75 ecu. so im good to go then?
Old Apr 10, 2008 | 04:45 PM
nicks-eg6's Avatar
x2 on everthing he said
Old Apr 10, 2008 | 04:46 PM
nicks-eg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_ej8 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, i got the ls manifold and obd1 p75 ecu. so im good to go then?</TD></TR></TABLE>
you need a obd2 ecu for the swap.
Old Apr 10, 2008 | 04:48 PM
slo_ej8's Avatar
im using a obd2-obd1 conversion harness.
Old Apr 10, 2008 | 05:58 PM
Slammed_am's Avatar
If he was to use a vtec head, would it be straight bolt up and plug n play?
Old Apr 10, 2008 | 07:10 PM
slo_ej8's Avatar
Default Re: (Slammed_am)
i believe it will be.
Old Apr 10, 2008 | 07:26 PM
x0!'s Avatar
x0!
Default Re: (slo_ej8)
its not as easy as slapping the head on. you need the kit, head studs suggested etc,,
Old Apr 10, 2008 | 07:29 PM
slo_ej8's Avatar
Default Re: (x0!)
i think he was talking about the wire harness being plug n play.
jr477
Oct 7, 2012 08:59 AM
Dr.Honda
Apr 30, 2007 01:30 AM
_unclejuice
Feb 9, 2007 12:25 PM
Adam West
Nov 13, 2005 04:01 PM
jeekE_
12
Jul 27, 2002 09:31 AM
