99 civic ex 5spd bucking violently, studdering at low rpm NO CODES
Old Apr 10, 2008 | 03:32 PM
mrnorm's Avatar
Default 99 civic ex 5spd bucking violently, studdering at low rpm NO CODES
I have replaced cap, rotor, coil, wires, plugs, o2, throttle body, cat, muffler, intake, map sens., idle control valve, fuel pump, fuel filter, fuel injectors, STILL NO FIX AND NO CODES. PLEASE HELP!! I WANT TO BURN IT TO THE GROUND
Old Apr 10, 2008 | 03:37 PM
idonoduu12's Avatar
Default Re: 99 civic ex 5spd bucking violently, studdering at low rpm NO CODES (mrnorm)
NO codes means its not an electrical problem most likely. Must me mechanical. Check your compression. Is it all the time, at a certian rpm range, or at a certian speed??
Old Apr 10, 2008 | 03:45 PM
mrnorm's Avatar
Default Re: 99 civic ex 5spd bucking violently, studdering at low rpm NO CODES (idonoduu12)
has good compression and it is hard to say when it will happen cold hot long drives short drives doesnt matter its intermitent
Old Apr 10, 2008 | 03:49 PM
Former User's Avatar
You might want to troubleshoot the EGR system, if you have one.
Old Apr 10, 2008 | 03:51 PM
mrnorm's Avatar
Default Re: 99 civic ex 5spd bucking violently, studdering at low rpm NO CODES (RonJ@HT)
most of the time the car runs like new and i dont think it has an egr valve
Old Apr 10, 2008 | 03:55 PM
A faulty CKP sensor and valve clearance out of spec are some other possibilities.
Old Apr 10, 2008 | 03:58 PM
mrnorm's Avatar
CKP has been a thought of mine but i think it would have thrown a code
Old Apr 10, 2008 | 04:01 PM
mrnorm's Avatar
I took it to the honda certified dealer and they cant figure this thing out. cost me a day with no car and cash i didnt need to spend
Modified by mrnorm at 6:05 PM 4/10/2008
Old Apr 10, 2008 | 05:12 PM
JSPECSIR's Avatar
have you checkaed all the engine grounds? mainly the one on the thermostat housing?
Old Apr 10, 2008 | 05:56 PM
z6hatchboy's Avatar
Default Re: 99 civic ex 5spd bucking violently, studdering at low rpm NO CODES (JSPECSIR)
Check your valve lash clearance, and the adjustments on the t/b (idle and the allen screw below the butterfly cam where the throttle cable hooks to)
Dawsman23
Feb 21, 2017 07:46 AM
MrMiller
May 9, 2013 08:50 PM
sethmoman
Dec 18, 2011 02:23 PM
iamlinu
Mar 29, 2007 03:32 PM
clemsonteg
22
Aug 24, 2006 09:39 AM
