need an opinion/input
Old Apr 10, 2008 | 01:35 PM
obuhmyuh's Avatar
Default need an opinion/input
currently have a d15b sohc vtec motor. i plan to boost with a stock bottom end sometime in the near future (before the end of the year). I have a spare d16a (jdm sohc vtec) head. I'm wondering if I should keep the head that I have on there, or do all of my upgrades to the old head...
either way im planning on upgrading (all at once):
valve springs
retainers
camshaft
intake mani
if I use the old d16a I'll probably have it sent out and professionally worked on (milling, etc)
TIA
Old Apr 10, 2008 | 10:33 PM
obuhmyuh's Avatar
Default Re: need an opinion/input (obuhmyuh)
bumppp
Old Apr 11, 2008 | 09:57 AM
blk92_d16's Avatar
I'm only aware off one JDM D-series engine...the JDM D15B. The D16A6 was a non-vtec '88-'91 Si head I believe. I'd use that D15B you have there cuz it's pretty much a Z6 head. GL!
Old Apr 11, 2008 | 10:09 AM
obuhmyuh's Avatar
Default Re: (blk92_d16)
the d16a is the jdm version of the d16z6 ( i can take a picture of it if you want). but i was just wondering if it would be easier to do these things to a head that wasn't on the car... and if it is would that be a good call.
Old Apr 11, 2008 | 11:06 AM
blk92_d16's Avatar
I would much rather build something off the car than otherwise, so you say it's another Z6 equilvelant...go for it! So what is the head code on that D16a anyways? Just never came across one before I guess.
Old Apr 11, 2008 | 11:18 AM
obuhmyuh's Avatar
not the most sure lemme go check... it says p08-6??
Old Apr 11, 2008 | 11:21 AM
obuhmyuh's Avatar
Default Re: (obuhmyuh)
92 Si D16Z6 5sp------- P08-2 (9/2) stamped on RS of code.
93 Si D16Z6 5sp-------P08-4 (9/3) stamped on rs of head
93 EX D16Z6 5spd----- P08-4
93 EX D16Z6 5sp-------P08-3
94 EX D16z6 5 spd---- PO8-2
94 Si D16z6 5sp-------- P08-3
94 EX D16Z6 5sp--------P08-4
94 SI D16z6 5sp -------P08-5
95 EX D16Z6 Auto------P08-2
mine has 9/3 before it so im guess a 1993 jdm d16a
Old Apr 11, 2008 | 09:08 PM
obuhmyuh's Avatar
bump
Old Apr 12, 2008 | 11:22 AM
obuhmyuh's Avatar
one more bumppp
Old Apr 12, 2008 | 11:26 AM
btk2334's Avatar
just by way of on our off the car, anything off the car is easier to work with, atleast in my opinion. If the heads are equivalent as you say, then work the one thats off, send it out, whatever, that way all you gotta do is ubolt the old and bolt up the new
Old Apr 12, 2008 | 01:56 PM
obuhmyuh's Avatar
Default Re: (btk2334)
my thinking exactly, the reason for my post is that im new to engine building, and just trying to get the easy questions out of the way so i can learn more... when you mill the head you need a different hg right?
Old Apr 12, 2008 | 02:00 PM
d.a ryda's Avatar
i wanna boost my single to .even tho i know it wont be that fast lol
Old Apr 12, 2008 | 02:12 PM
obuhmyuh's Avatar
Default Re: (d.a ryda)
who cares about fast??? i just care about fun, working on my car is fun, and so is making your car faster... boost+built = fun so what if its not the fastest, it never will be. SOHC parts are cheap and interchangeable which makes them ideal for boost and fun
artin01
Oct 25, 2007 08:08 AM
RoadconeTuning
Sep 9, 2007 07:32 PM
tobe1424
Apr 13, 2006 12:05 PM
ssbpturbohatch
May 30, 2005 09:30 AM
