just picked up toda spec b's, need input
Old Apr 10, 2008 | 01:34 PM
krucial7integra's Avatar
Default just picked up toda spec b's, need input
Help me out here honda-tech, I just picked up a set of toda spec b's and need to know what it will take to make it work.
So far I have the camshafts, still waiting on valvesprings/retainers, cam gears, timing belt from toda. Is it possible to run these with a stock block gsr? Of course I will be getting it tuned but will p72 pistons work for now? Need advice from someone who has actually ran these. Also, I do realize that these cams won't be at full potential until compression is bumped.
thanks for any advice.
Old Apr 10, 2008 | 10:48 PM
civicstar's Avatar
Default Re: just picked up toda spec b's, need input (krucial7integra)
your valve train will get destroyed and your rockers will get messed up and grind your cams with odd shaped lobes. possbily break a retainer and drop a valve, i recommend not doing it, but you can if you want
Old Apr 11, 2008 | 02:44 PM
Brick Top's Avatar
^^ do what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krucial7integra &raquo;</TD></TR><TR><TD CLASS="quote"> I do realize that these cams won't be at full potential until compression is bumped. </TD></TR></TABLE>
why not wait till then?
Old Apr 11, 2008 | 03:02 PM
Default Re: just picked up toda spec b's, need input (Brick Top)
thats what I was thinking about, just waiting it out.
As far as the spec b's destroying things, thats a myth. If you know how to correctly install these and check the clearances, then it should be fine.
Old Apr 12, 2008 | 12:44 AM
civicstar's Avatar
i've ran them on incorrect valve springs and retainers and the cam lobes got grinded down. test it out and see after a few thousand miles
Old Apr 12, 2008 | 11:54 AM
Brick Top's Avatar
Default Re: just picked up toda spec b's, need input (civicstar)
matching is a good idea. but your problem sounds more like coil bind.
Old Apr 12, 2008 | 05:34 PM
cvp467's Avatar
I ran a B16A with a civic Type R pistons and the B's for about 3 years and never broke nothing.I use Toda valve springs and Skunk2 retainers.13.4@100mph
PowerHouse
Apr 5, 2004 11:40 PM
Slow96RedEk
Jan 14, 2004 09:45 AM
jessevtec
17
Aug 5, 2003 04:52 PM
TakumiFujiwara
16
May 10, 2003 06:58 PM
oldskooljdm
Apr 12, 2003 03:28 PM
