Replacing all 4 brake rotors and pad sets. Decided on Centric E-coated w/OEM pads.
As the title states, I'm going to give the Centric rotors a try. I hope the E-coating holds up for at least a year. Anyone have long term experience with them? As for the pads, I'm satisfied with the OEM pad performance and dust. I'm reluctant to experiment with possibly sub-standard performance pads. The application is for a daily driver, no track use, so forget about slotted/cross drilled/ or big brake mods.
Other suggestions for rotor/pad combinations are welcome, but keep in mind the intended use. My main concern is to get rotors that will not get as nasty looking as my original stock rotors. (I realize iron rusts, but I firmly believe mine were from a bad batch. Never had as much rust or pads bonding to the rotors overnight after a rain than these.)
