Meth injection
Old Apr 10, 2008 | 11:43 AM
EJ8 GSR-T's Avatar
Default Meth injection
Just starting to look into this, doing research and such. I am wondering what systems you guys use? I have found one from labonte motor sports and its interesting because you can incorporate a protection solenoid that will only allow WG boost should it sense any error. Any input?
Old Apr 11, 2008 | 02:56 AM
SpeedEuphoria's Avatar
Default Re: Meth injection (EJ8 GSR-T)
It depends on what exactly you want to spend and what you feel ok with. Also what you have to tune with helps decide on the nozzle size and meth/water mix.
Some use basic kits and some get high tech, Aquamist has good stuff.
Personally I have a SMC progressive universal trunk kit, 10GPH straight meth.
Old Apr 13, 2008 | 04:49 PM
EJ8 GSR-T's Avatar
Default Re: Meth injection (SpeedEuphoria)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedEuphoria &raquo;</TD></TR><TR><TD CLASS="quote">It depends on what exactly you want to spend and what you feel ok with. Also what you have to tune with helps decide on the nozzle size and meth/water mix.
Personally I have a SMC progressive universal trunk kit, 10GPH straight meth.</TD></TR></TABLE>
Money is not really an issue, however i dont alway go by the "more expensive is better" ideal. Also i have heard things about the more complex systems failing. The car is tuned with hondata s300. If i were to want something somewhat simple, and reliable..what would you recommend. Also i think i may run denatured alcohol instead of meth.
Old Apr 13, 2008 | 09:23 PM
4doorekITR's Avatar
crystle meth will make you and your car go really really fast..J/k,sorry for being stupid.couldnt resist
Old Apr 13, 2008 | 10:20 PM
EJ8 GSR-T's Avatar
Default Re: (4doorekITR)
Haha...well thanks for the...free bump??
Old Apr 15, 2008 | 03:54 PM
240sx4u's Avatar
Default Re: (EJ8 GSR-T)
I have a kit from http://www.alky-control.com on my 240sx. I also have a couple buddies making big HP with these kits.
If nothing else, get a progressive kit! If you maintain the system properly (cleaning the inline filter etc..) its very reliable.
Evan
coupon
Sep 5, 2005 01:03 PM
AllMoToRB18c
Aug 18, 2005 06:31 AM
CooBlueDAB
Audio / Security / Video
May 3, 2005 06:00 PM
hatchback
Jun 26, 2003 07:08 PM
