temperature gauge rose to HOT
Old Jul 10, 2002 | 11:02 PM
satintegra's Avatar
Default temperature gauge rose to HOT
what could be the problem when the temperature gauge rose all the way to HOT? there was no smoke, only a busted radiator hose.
what is wrong with the teg?
Old Jul 10, 2002 | 11:06 PM
Calavera's Avatar
Default Re: temperature gauge rose to HOT (satintegra)
Doesn't that mean your radiator is leaking? If so. then you're too low on radiator fluid. If it is too low, there is not enough to properly cool the engine which leads to overheating.
Get the hose fixed, then add radiator fluid--don't know what the proper term is - and you're good to go.
Old Jul 10, 2002 | 11:14 PM
satintegra's Avatar
Default Re: temperature gauge rose to HOT (Calavera)
forgot to mention that the radiator hose was replaced and coolant was added, but the temperature gauge still rose to HOT as it accelerated.
Old Jul 10, 2002 | 11:36 PM
MIKEGSR95's Avatar
New User
I'm having overheating probs too.. look up my post... look at the part on bleeding the coolant..
[Modified by MIKEGSR95, 8:37 AM 7/11/2002]
Old Jul 10, 2002 | 11:39 PM
B-Series Sol's Avatar
is your fan working? is it plugged in? are you sure your radiator fluid is at 50/50?
If so, it might be a thermostat problem.. cheap. I have heard of radiators and cores getting clogged up by using the wrong kind of radiator fluid too.. some sort of crystals formed... bad news
Old Jul 11, 2002 | 12:49 AM
ken's Avatar
ken
Default Re: temperature gauge rose to HOT (B-Series Sol)
Things to check...
1) Plug the primary fan into the secondary fan's jack (barely stretches) and make sure the fan works (turn the engine on and A/C on to test)
2) Check the fuse for the primary fan (its under the hood, forgot the label)
3) Check/replace thermostat
Old Jul 11, 2002 | 01:13 AM
Anthony K's Avatar
New User
Default Re: temperature gauge rose to HOT (ken)
Or...check to see if you have any coolant left.
Old Jul 11, 2002 | 12:06 PM
Eva01's Avatar
Happened to me after my timing belt was changed. Turned out to be an air bubble in the coolant line. Just bleed the system and that should cure the prob.
Old Jul 11, 2002 | 10:37 PM
satintegra's Avatar
Default Re: temperature gauge rose to HOT (Eva01)
thanks for the helpful information people.
it turned out to be the thermostat that failed. replaced it and everything is back to normal now.
ShotnVA777
Jan 9, 2014 04:13 AM
Lithel
Nov 3, 2009 08:38 AM
krazyhmongboi
28
Feb 13, 2007 07:58 PM
Eckz2k
Jan 25, 2003 08:43 AM
4doorH22
18
Jan 19, 2002 01:06 PM
