Automatic Transmission - Weird noise when shifting to drive
Old Apr 10, 2008 | 08:45 AM
rhmabman's Avatar
Default Automatic Transmission - Weird noise when shifting to drive
Hi,
I have a 1999 Honda Civic EX Auto Transmission.
I would just like to know if anyone here is experiencing a weird grinding noise everytime you shift the transmission from either Park, Neutral or Reverse to Drive.
It is just a 2 or 3 seconds noise after shifting to drive and stepping on the pedal. It's kinda annoying though...don't want to think yet that there is a problem in the auto transmission...
Old Apr 10, 2008 | 08:54 AM
ferio252's Avatar
Default Re: Automatic Transmission - Weird noise when shifting to drive (rhmabman)
I had the same problem along with longer engagement time. Does it sound like a whir and click? Long story short, my first gear was completely gone and I needed to swap my transmission.
Old Apr 10, 2008 | 09:06 AM
rhmabman's Avatar
Default Re: Automatic Transmission - Weird noise when shifting to drive (ferio252)
it's just a whir sound for 2 or 3 seconds everytime I shift to drive...how long have you been dealing with this before you had it swapped? same transmission? auto?
for how much did it cost you?
Old Apr 10, 2008 | 10:22 AM
ferio252's Avatar
For me, it was a whir and click when you pressed the gas lightly to start moving. It started out one day and became to troublesome to bother after 3 months or so . A used transmission I sourced from criagslist that had 95k for $175.00
Bump for someone else to help out b/c it this may be something else then a worn tranny. Solenoids?
Old Apr 10, 2008 | 11:24 AM
Gearspeed-Performance's Avatar
These transmissions do have a couple valve body springs that tend to break and cause shift issues Sounds like you will need a replacement soon.
Old Apr 22, 2008 | 05:31 PM
rhmabman's Avatar
Default Re: Automatic Transmission - Weird noise when shifting to drive (Special Projects MS)
I recently had the car serviced by a Honda Dealer. All the fluids were changed including the transmission fluid using ATF-Z1. The mechanic told me that there is nothing wrong with the transmission. He test drive my car and the transmission shifts smoothly. He did not hear any grinding noise that I described to him whenever the gear is shifted to drive. I went home and the next morning I heard the noise again.
I went back to the dealer to have it checked once again. It was a 15 minutes drive. When I arrived there the same thing happened. I cannot replicate the noise to the mechanic. The mechanic cannot diagnose because he is not hearing anything...Is it because the engine is still hot when I drove my car from my place to the dealership?
Is anyone experiencing the same thing in their auto transmission when the engine is still cold?
Old May 15, 2009 | 08:15 PM
psmoss's Avatar
I don't know if this is exactly what you are experiencing, but I thought I'd add to your thread.
1996 Civic EX coupe, ~200k miles
Intermittently, the car will emit godawful squealing sounds when moving to/from P/R/D (can't recall right off if this happens when moving into Neutral). I noticed that when this happens, the climate control fan doesn't blow either.
The only solution has been to turn the car off and restart. Then it's usually fine.
I have no idea what this means, but I thought I'd throw it out there.
Old Aug 29, 2017 | 07:16 AM
mike Golden's Avatar
I have a 2016 honda accord with the cvt transmission and after driving for about 20 mins or so when i put it into park i hear this sort of buzzing noise it also does it when i put it into reverse , it does not do it everytime just every so often it doesnt do it long just a few seconds or so ive had it back to the dealer n they heard thw noise but cannot figure out what it is or where its coming from has anyone else have this issue??
Old Aug 29, 2017 | 09:19 AM
CandyRedRC46's Avatar
FFS MAN, START YOUR OWN THREAD, IN THE CORRECT SECTION, INSTEAD OF BUMPING AN 8 YEAR OLD THREAD, ABOUT A CAR THAT HAS NOTHING TO DO WITH YOUR 2016 HONDA ACCORD CVT.
Old Aug 31, 2017 | 12:12 AM
Stfu bro I wasn't even paying attention **** ****.
Old Sep 5, 2017 | 07:23 AM
Congrats, you are an idiot.
Old Feb 21, 2018 | 09:16 PM
Giuseppe Gg's Avatar
same problem here. My civic is been doing it for a while. Only when its cold and only when you shift in to D or R. Did you find out what the problem is?
elteejee
Honda Insight & CR-Z Hybrid
Jan 17, 2018 12:26 PM
leeh795
Nov 14, 2009 07:23 PM
dust2285
Honda Civic (2006 - 2015)
11
Dec 3, 2006 07:46 AM
AcCoRd_HyBrId
May 10, 2002 09:37 AM
