H22a water pump water leaking
Old Apr 10, 2008 | 08:09 AM
jameskhan's Avatar
Default H22a water pump water leaking
Hi; water drips from the back part of my h22a. found a small hole at back of eng blocl just behind water pump. My mechanic says water pump starts to leak n need to replace it.
Before this happened, we removed the fuel injection's water thermostat to allow direct water flow....then water pump starts this leak.
water temp. is normal at the half mark.
but radiator water needs slight refill due to this droplets leking. thanks n will update replacemt progress,,,,need info on genuine part i.e. stamp as made in japan n not japan only...
Found NPW brand replacement part embossed brand and Made in Japan on the part itself.
Modified by jameskhan at 8:42 AM 4/19/2008
new_climber
16
Mar 12, 2018 08:56 PM
tominos
Sep 10, 2004 08:38 PM
B18PoweredCivic
Jul 25, 2003 01:37 PM
raene
Mar 1, 2003 05:06 PM
