What clutch is better for boost? debating...LOOK
Old Apr 10, 2008 | 06:14 AM
marc100's Avatar
Default What clutch is better for boost? debating...LOOK
http://shopping.lightningmotor...age=1
OR
http://thmotorsports.com/exedy....aspx
Understand im budgeting in the process...
Old Apr 10, 2008 | 09:18 AM
blk92_d16's Avatar
Might I recommend an LSD branded clutch.
Old Apr 10, 2008 | 09:26 AM
marc100's Avatar
Default Re: (blk92_d16)
well whats wrong with my other 2 options?
marc100's Avatar
Default Re: (marc100)
bump
Old Apr 10, 2008 | 03:59 PM
marc100's Avatar
Bump Help me out!
Old Apr 10, 2008 | 04:21 PM
Luserkid's Avatar
What kind of power are you looking for?
Old Apr 10, 2008 | 04:44 PM
Schister66's Avatar
Man U FTW
Your clutch choice will depend on the power you plan to make. The Exedy organic is not much better than a stock clutch and wont really hold much over 190wtq...not to mention if you ever plan to go to the track, its going to be toast. I would look at a Clutchmasters Stage 3 or Stage 4. I'm going with the Stage 4 on my 450whp build
Old Apr 10, 2008 | 06:57 PM
lilo_goki's Avatar
if ur turbo, don't get anything that is stage 1, it will be a waste of money. get at least stage 2 and up, depending on ur hp. Action makes a clutch to support 500 whp for pretty cheap and they're good as well.
Old Apr 10, 2008 | 07:39 PM
marc100's Avatar
Default Re: (lilo_goki)
alrighty guys i might go with a stage 2 or 3 clutch masters then...Thanks...and I was thinking a fidanza flywheel?
Old Apr 10, 2008 | 09:13 PM
Schister66's Avatar
Man U FTW
There are a lot of things to consider when picking a clutch and flywheel combination to match your engine and turbo setup. On my setup i have an ACT 11lb fly and an Exedy stage 2 clutch. It provides good streetability and quick response. If you were to go lighter you may fall out of boost during shifts depending on your turbo choice.
Old Apr 11, 2008 | 05:37 AM
marc100's Avatar
Default Re: (Schister66)
Ill take that in consideration...thanks! I would say atleast 200whp like 8lbs of boost havnt decided what turbo i should go with...
Old Apr 11, 2008 | 06:29 AM
schpiel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marc100 &raquo;</TD></TR><TR><TD CLASS="quote">Ill take that in consideration...thanks! I would say atleast 200whp like 8lbs of boost havnt decided what turbo i should go with...</TD></TR></TABLE>
200whp? This is a d-series turbo build I assume?
Old Apr 11, 2008 | 06:30 AM
marc100's Avatar
Default Re: (schpiel)
Correct!
Old Apr 11, 2008 | 06:49 AM
schpiel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marc100 &raquo;</TD></TR><TR><TD CLASS="quote">Correct!</TD></TR></TABLE>
Nice! I was about to say, come on man, 200whp on a b-series turbo, I can do that all motor EASY! haha
Old Apr 11, 2008 | 06:52 AM
marc100's Avatar
haha...I wish I had th money for a b series motor But I can work with my d series...so it's all good!
Old Apr 11, 2008 | 06:54 AM
marc100's Avatar
Any reccomendations on what is a good turbo kit for and what money I would probably spend...
Old Apr 11, 2008 | 08:17 AM
schpiel's Avatar
These are a couple websites that are filled with information...in a matter of minutes you can learn about all kinds of b.a. setups, some are inexpensive also!
http://www.d-series.org
http://www.homemadeturbo.com
http://www.turbod16.com
Those last two websites are ones that I would do quite a bit of research on. The first is mainly just a huge database with all sorts of info on the d-series motors.
Good luck man!
Old Apr 11, 2008 | 12:08 PM
marc100's Avatar
thanks!
Old Apr 11, 2008 | 12:15 PM
slacks's Avatar
a friend of mine suggested to me a 6 puck or 4 puck clutch. apparently it's not too streetable but it can handle a good amount of torque
look up xtd clutches here on HT. their 6 puck stage three clutch apparently are amazing but the other ones that are weaker are ****.
EG6 Love
Transmission & Drivetrain
15
Jul 23, 2013 07:19 AM
lakai_19
Sep 14, 2010 02:24 PM
LilTeggy2011
Apr 9, 2010 11:36 PM
HondamanXxX
28
Jul 6, 2007 08:45 AM
