All motor build..What next?
Old Apr 9, 2008 | 07:00 PM
xsi90teg's Avatar
Default All motor build..What next?
hey guys i have a jdm b16a with a b17 tranny. i have some work done and just wanna know what else i should do for some power gains,
p&p b16a head
High compression pisons compression about 12to1
cometic head gasket(thin)
block gaurd
skunk2 titainum valvetrain(flattop valves, springs and retainers)
skunk2 IM
skunk2 TB
everything is port matched
aem Fuel Rail
aem FPR (40 psi)
inake
headers back exhaust
i do wanna eventually get a b16 tranny for shorter gears so thats next just dont know what else to do maybe cams and cam gears just need some ideas and stuff to help me keep going. Thanks in advance.
Old Apr 9, 2008 | 07:16 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: All motor build..What next? (xsi90teg)
Some cams would really set that off nicely with a good tune
I'm running skunk2 stage 2's and there not to bad. But I don't have as much done as you. good luck and post up your results.
Old Apr 9, 2008 | 07:20 PM
xsi90teg's Avatar
Default Re: All motor build..What next? (SlammedDC2)
n e suggestions? i was looking at some skunks stage 3s but i dontknowif thats a big jump or not.
Old Apr 9, 2008 | 07:25 PM
SlammedDC2's Avatar
Semper Fidelis
Honestly I would say some stage 2's. I really think it would suprise you with what you have.
I have them in mine, however I'm not running as high comp. as you. (previous owner was going to boost and I am to lazy...er broke to change that.
You've already got the bottom end done, and sounds like all your lacking in the head is some cams and adjustable cam gears for tuning.
Old Apr 9, 2008 | 07:27 PM
HONDRETTI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
You've already got the bottom end done, and sounds like all your lacking in the head is some cams and adjustable cam gears for tuning.</TD></TR></TABLE>
x2
winman517
Feb 13, 2003 07:15 AM
Slipped_Away03
Feb 6, 2003 12:03 PM
gsr squirrel
Dec 6, 2002 07:44 PM
ghettoracer
Feb 27, 2002 02:27 PM
