wheel spacer for bogarts
you should be able to use a standard 1/8" 4 lug spacer / I do - you just have to be shure to center it as you tighten wheel , lug holes are big enough to get "off center" letting lug nut try to tighten on outside of spacer -
even better suggetion ,than mine , was in a rush {as always} the day i got mine and have made them work , wish i had'nt sold the set i had with proper offset..
also I may have "shaved" these calipers "a little bit"
another question, i also have an integra with type r 5 lug, i was wondering what kind of wheel and slick combination for 611 hp?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt »</TD></TR><TR><TD CLASS="quote">i dont know how different the offset is but i have a 99 civic CX with lensos and 9.0" MT and i have to have half inch spacers</TD></TR></TABLE>
Why did you have to use a spacer on cx brakes? Those wheels are supposed to clear even integra brakes.
X2...but on Bogarts.
i clear brakes, i have to use spacers to space the tire from the spindle arm near the upper ball joint.
haha, now.... that makes perfect sense. bogarts offsett is a lil higher, the wheel literally sticks past the fender.
heres a pic. Bogart 25x8.7x13 M&H
Weld import magnum 24.5x9x13 MT
93grayeg
May 12, 2011 09:37 AM
nsxtasy
Feb 6, 2006 03:47 PM
