built SOHC
Block:
D16Y7
Wiesco 9:1 pistons (75.5mm)
Eagle Rods
MicroPolished Crank
Underdrive Crank Pulley
New Honda oil pump, ported, heavier spring
All Moving parts are full 0gram race ballenced
Head:
D16Z6
new stock valves and radius valve job
SuperTech Valve Springs
SuperTech Ti Retainers
Comp Cams Patr # 59300 (biggest sohc cam made for boost) lift @.050 VTEC lift; int. .456" exh. .428 ", dur @.050" int. .256" exh. .268" ( lopes at idle hard core)
ARP head studs
Cometic Head gasket (.030")
Unothadox cam gear
new Honda timing belt, water pump, tensioner
Engine all balenced and blue printed.
Clutch:
Clutchmasters stage 5, (4 puck steel pad disk, Double diafram 2600lbs. pressure plate.
Trans:
98' civic ex with appr. 50K, no grinds w/ new axle seals.
intake man. ported and polished, opening for a 70mm thottle body.
Full setup has about 3k miles, never boosted on yet.
asking $3k obo. engine was built to make about 450hp on pump gas
Honda D16 stainless turbo manifold built my hickamhatch $550 obo
40mm wastegate$125 obo
D16 SRP turbo pistons, Eagle rods(big bolt) $450 obo
make offers need this stuff gone asap!!! Dustin-817-269-3964 or pm
also have a garage full of honda parts if you need it, i prob got it, give me a call and find out
bran new gsr unorthodox under drive crank pully MAKE ME A OFFER
Modified by turbo-2nr at 10:44 PM 4/11/2008
