b16 del sol
any body know a quick way to had some power to my del sol this is wats done so far thanks
1. completely rebuilt now has 3500 miles on it
2. arp head studs
3. type r style pistons (hastenings)
4. port job
5. valve job
6. mild cams
7. bored .20 over
8. reconditioned rods
9. intake, header back exhaust and street tune
10. 10.5.1 compression
2. arp head studs
4. port job
5. valve job
6. mild cams
7. bored .20 over
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg2jr »</TD></TR><TR><TD CLASS="quote">i can tell u this, you've done more than most people out their. fastest way to get more power would be turbo</TD></TR></TABLE>
couldnt have said it better
boost it, that'll be a fun ride.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obuhmyuh »</TD></TR><TR><TD CLASS="quote">
boost it, that'll be a fun ride.</TD></TR></TABLE>
your going to have to be careful with boost beings you have upped the compression ratio. each point you go up makes boosting that much harder because high compression and boost dont mix. if you are careful and have a amazing tune done on it you should be fine. high CR means a more precise turbo setup
