b18c vs. b18c
Old Apr 9, 2008 | 01:10 PM
f-it3's Avatar
Default b18c vs. b18c
My buddy just recently got a eg hatchback with a b18c in it. He originally was told it was a jdm gsr, but now he thinks it is a type-r, b18c. Is there any way to distinguish the two apart?
Old Apr 9, 2008 | 01:22 PM
phatfx's Avatar
look at the transmission
a 96spec type r will have J4D stamped to it
if its a 98+ spec type r will have N3E stamped to it
but there's always the possibility it could be a gsr engine with a type r tranny
also the gsr comes with the black valve cover and type r comes red. however there is another possibility that the valve cover was changed to a red one.
Old Apr 9, 2008 | 01:26 PM
f-it3's Avatar
Default Re: (phatfx)
well i know the trans is an s80, jdm gsr right? and the vc is black, kid that had it before him had a red one but kept it and put a black one on.
Old Apr 9, 2008 | 01:32 PM
Rdriver's Avatar
Default Re: (f-it3)
The gsr head will be stamped P72....
Old Apr 9, 2008 | 01:44 PM
f-it3's Avatar
Default Re: (Rdriver)
right ill check that later tonite. thank you
Old Apr 9, 2008 | 01:54 PM
espanol's Avatar
Default Re: (f-it3)
It's easy to determine a jdm gsr from a jdm type R by looking at the intake manifold.(unless the motor has an aftermarket intake manifold)..but if it's stock just look at the intake manifold. The type R manifold looks like a b16 while a gsr manifold looks like a upside down fruitcake.
Old Apr 9, 2008 | 02:51 PM
f-it3's Avatar
Default Re: (espanol)
yea i had thought about that too...but its aftermarket
Old Apr 9, 2008 | 03:20 PM
nutsack's Avatar
disassemble the motor, if you see P73 and R stamped on the pistons, rods, and crank then you are good to go.
Old Apr 9, 2008 | 04:27 PM
DejaVu88's Avatar
Well if its a JDM GSR it'll be fast, and if its a JDM B18C R it'll be really fast. What's it rev to?
If he "had a red valve cover but kept it and put a black one on" it would be a R. Tell him to show it to you. Only a moron would sell a car with a jdm B18C-R as a car with a jdm GSR.
To say the least, I think that if it was a JDM B18C then you would both KNOW it.
Old Apr 9, 2008 | 06:48 PM
f-it3's Avatar
Default Re: (DejaVu88)
well like rdriver said...it def has p72 on the head, and its fast but not that fast...door to door with an evo
Old Apr 9, 2008 | 08:46 PM
MiraiZ's Avatar
Default Re: (f-it3)
test the compression or remove the head, also what ECU is your friend using? that might give a clue as to what the engine is
Old Apr 10, 2008 | 04:54 AM
KnuckleZ's Avatar
Default Re: (MiraiZ)
So no PR3 on the head? Prob a GSR. I can't see why someone would swap a P72 over a PR3.
Old Apr 10, 2008 | 05:01 AM
tartje's Avatar
Default Re: (f-it3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f-it3 &raquo;</TD></TR><TR><TD CLASS="quote">well like rdriver said...it def has p72 on the head, and its fast but not that fast...door to door with an evo</TD></TR></TABLE>
the Evo wasn't trying then
Old Apr 10, 2008 | 05:53 AM
CW-ITR's Avatar
Default Re: (tartje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote"> the Evo wasn't trying then</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f-it3 &raquo;</TD></TR><TR><TD CLASS="quote">My buddy just recently got a eg hatchback with a b18c in it. He originally was told it was a jdm gsr, but now he thinks it is a type-r, b18c. Is there any way to distinguish the two apart?</TD></TR></TABLE>
Old Apr 10, 2008 | 06:00 AM
tartje's Avatar
Default Re: (CW-ITR)
are you kidding me, a hatch with a standard B18C (probably a GS-R motor) keeping up with a 300bhp Evo?
pull the other one...
Old Apr 10, 2008 | 06:44 AM
Bradstard's Avatar
x2
Old Apr 10, 2008 | 06:49 AM
b18c5ej8's Avatar
Default Re: (Bradstard)
it depends i have a jdm b18c R with a 65 shot in my coupe. and i stayed side by side with and evo 9 with upgraded turbo.
Old Apr 10, 2008 | 08:42 AM
Little_Nolan's Avatar
x3
Old Apr 10, 2008 | 01:08 PM
IntegraType-R's Avatar
Default Re: (boostn92vx)
So your saying.. a bolt on b18c hatch wont keep up with a evo??
I walk evo8/9's from a 20 punch all day.. i'm alottt more modded but still all motor..
evo's aren't fast.. i used to have a buddy who owned a bolt on one and i drove it.. alot..
at least down here bolt on gsr's motors in hatches are fast.. like.. 13.8 fast..
Old Apr 10, 2008 | 01:10 PM
GO-FIGHT-KILL's Avatar
13.8 is fast?
But for real, f*ck an EVO, I can walk all over an EVO... An EVO VIII, with 4 people in the car, a burnt clutch, and a boost leak.
Old Apr 10, 2008 | 01:15 PM
Default Re: (GO-FIGHT-KILL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">13.8 is fast?
But for real, f*ck an EVO, I can walk all over an EVO... An EVO VIII, with 4 people in the car, a burnt clutch, and a boost leak.</TD></TR></TABLE>
Now now.. before someone twist my words to make me look like an idiot or try too anyway..
13.8 at like 100+mph is quiet fast actually considering the motor really only has a exhaust, and intake.. otherwise everything else was stock.. Good driver on street tires cut a 2.0 60' I believe thats fast enough for a pretty stock car.. of course i live in louisiana.. so alttitude doesn't play a role down here like everywhere else
Lemme say again, evo's aren't fast.. it was my dream car for about 6 years until i drove one constantly because a good friend owned one.. to me its now like another car.. and it isn't fast.. they're overrated bhp anyway, they put down alittle over 240 to the wheels. after 80mph awd is ****.
Old Apr 10, 2008 | 01:44 PM
b18c5ej8's Avatar
Default Re: (IntegraType-R)
yea i live louisiana too. and EVOs arent fast mid to high 13s stock. and 13.8 @ 100 is pretty quick. yea a stripped eg hatch with a gsr is pretty quick. it could easily hang with an evo. from a dig it would be hard but from a roll easy. where is a good tuning place in La?
Old Apr 10, 2008 | 01:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R &raquo;</TD></TR><TR><TD CLASS="quote">
Lemme say again, evo's aren't fast.. it was my dream car for about 6 years until i drove one constantly because a good friend owned one.. to me its now like another car.. and it isn't fast.. they're overrated bhp anyway, they put down alittle over 240 to the wheels. after 80mph awd is ****.</TD></TR></TABLE>
Who tried to twist your words?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R &raquo;</TD></TR><TR><TD CLASS="quote">at least down here bolt on gsr's motors in hatches are fast.. like.. 13.8 fast..</TD></TR></TABLE>
To which I responded:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-POST-***** &raquo;</TD></TR><TR><TD CLASS="quote">13.8 is fast?</TD></TR></TABLE>
No twisting. No attempts to make you look like an idiot... Just asking, "13.8 is fast?"
EVOs are cool cars, I would absolutely LOVE one for a daily driver. 4 doors, easy to drive, decent torque, nice styling, no need for an aftermarket seat so I can fit my tall *** in it comfortably. Perfect daily driver. Not to mention, with a few grand in parts, it can be an incredibly fun car to drive, on the strip, on the street, or around some turns.
I would not, however, sell my Type-R to buy one.
Old Apr 10, 2008 | 02:06 PM
The Dude's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">the Evo wasn't trying then</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">are you kidding me, a hatch with a standard B18C (probably a GS-R motor) keeping up with a 300bhp Evo?
pull the other one...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">
x2</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostn92vx &raquo;</TD></TR><TR><TD CLASS="quote">
x3</TD></TR></TABLE>
I owe someone sum at Ocho.
Old Apr 10, 2008 | 02:15 PM
The Dude's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">EVOs are pigs, I would absolutely LOVE one for a daily driver. 4 doors, easy to drive, decent torque, nice styling, no need for an aftermarket seat so I can fit my tall *** in it comfortably. Perfect daily driver. Not to mention, with a few grand in parts, it can be an incredibly fast pig, on the strip, on the street, or around some turns.
I would not, however, sell my Type-R to buy one.</TD></TR></TABLE>
Fixed above. Yo Jordon, have a .
Great minds think alike.
Modified by The Dude at 5:24 PM 4/10/2008
