Broken Tap
Old Apr 9, 2008 | 08:59 AM
Muckman's Avatar
Moderator in Chief
Default Broken Tap
I broke a tap off in a hole I was chasing. The angle got a little tweaked and it snapped below the top of the hole. Its hardened steel. Can I drill it out? Am I screwed?
Old Apr 9, 2008 | 09:02 AM
weiRtech's Avatar
OG Fabricator
can you reach it with some needle nose pliers to twist it? if not, try using a sharpened punch and hammer to lightly tap one of the flutes, reversing the tap out of the hole. if that doesn't work, your best bet is to take it to a shop to have it edm'd out. (electrical discharge machining). basically burns it out with no damage to the threads... but that can cost upwards of $50-$75.
Old Apr 9, 2008 | 09:16 AM
Muckman's Avatar
Moderator in Chief
Default Re: (weiRtech)
its below the surface of the hole so I can't get anything on it to twist it. Ive tried hammering on the flutes with an awl, which did nothing but mutilate it.
Can I drill this out with a special drill bit? I have a friend with a drill press. I dont really care about the threads they were screwed up anyways, I can helicoil if ness.
Im saving the EDM option for last.
Old Apr 9, 2008 | 09:32 AM
weiRtech's Avatar
OG Fabricator
try a carbide ball nose endmill, run it slow and use cutting oil. if you have to buy an endmill, it is going to cost you $25-$50 anyway, so you might as well take it to a shop.
Old Apr 9, 2008 | 04:15 PM
The Original Whitey's Avatar
Default Re: (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Can I drill this out with a special drill bit? I have a friend with a drill press. I dont really care about the threads they were screwed up anyways, I can helicoil if ness. </TD></TR></TABLE>
You'll be lucky not to scrap the part let alone put in a helicoil. We use to try everything to get taps out; drill, machine, waterjet, burn, ect and nothing really works. The only thing I never tried was an EDM, so maybe that would work.
Old Apr 9, 2008 | 04:49 PM
EGJDM's Avatar
Default Re: (The Original Whitey)
There is a part you can get called a tap extractor. They are made by walton, The work good if the tap is not to jammed up.
Old Apr 9, 2008 | 04:58 PM
Bailhatch's Avatar
Default Re: (EGJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGJDM &raquo;</TD></TR><TR><TD CLASS="quote">There is a part you can get called a tap extractor. They are made by walton, The work good if the tap is not to jammed up.</TD></TR></TABLE>
yes. those are great.
Old Apr 10, 2008 | 04:04 AM
Muckman's Avatar
Moderator in Chief
Im looking for a local shop with an EDM machine.
Do you guys think cobalt drill bits could drill hardened steel? Its designed for SS...
Old Apr 10, 2008 | 04:41 AM
weiRtech's Avatar
OG Fabricator
cobalt won't work very well. you need carbide if you go the drill route.
Old Apr 10, 2008 | 04:46 AM
Flashmn's Avatar
Cobalt is softer than the tap (afaik)...and it wont work too well. x2 on the carbide drill bit.
Old Apr 10, 2008 | 06:00 AM
T4 Neon's Avatar
Default Re: (Flashmn)
http://www.electroarc.com
Old Apr 10, 2008 | 01:39 PM
slowgti's Avatar
if it is in steel/stainless, i usually, just take a sharp chisel and break them in to little pieces. just take your time. if its aluminium, good luck.
Old Apr 11, 2008 | 09:50 AM
Muckman's Avatar
Moderator in Chief
Default Re: (slowgti)
Ok update. The Cobalt drill bits didnt touch it. But I tried a set of double cut carbide burrs that I had and they chewed it up good. But I mutilated the hole so I had to drill it bigger and retap 1 size bigger. (was even too big too helicoil)
DrGrEeNtHuMb
Welding / Fabrication
13
Jun 4, 2008 07:57 PM
hatch_
15
Feb 7, 2008 10:13 AM
contender
Feb 4, 2005 09:00 AM
Neptune
Jul 19, 2003 08:35 PM
ILOVEGIRLS
Mar 3, 2003 03:24 PM
