poor man's type r base map
lookin for a base map for my build, stock gsr block with b16 type r internals, with a p30 ecu, dont know if should go with a p28 or keep the p30 ,,this is a obd 1 set up in my 90 hatch stock intake,with headers !!!!!!!!!
A poor man's Type R does not a Type R make.
Information about which engine management you plan on running might be useful, if someone were actually inclined to help you.
Making your request here:
https://honda-tech.com/zeroforum?id=124 might yield you better results.
i dont have a b16. i have a gsr block and a b16 head completely done with ITR internals. the car is running off a p30 jdm ecu, it runs and i eliminatedd all check engine lights... the swap is starving... i need a map made for this application
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90hatchsityper »</TD></TR><TR><TD CLASS="quote">i need a map made for this application</TD></TR></TABLE>
What application? Hondata? Crome? Neptune? It kinda matters.
im going to keep it N/A, i am thinking p28 chipped.. for type r, but the only thing diff from my motor n a type r is a slightly bigger dome on the pistons.. i dont know what map i need for the ecu.
the car runs and drives.
its just not right it needs more..
i wont need a hondata im not boostin
do i need a chrome??
Look here:
http://forum.pgmfi.org/
And here:
http://www.hondata.com/aboutus.html
And here:
http://www.phearable.net/tech/....html
And here:
And here:
YOu need to do some research , hondata dosent even come with a boost controller , how would that make it boost specific , ?
i ran hondata on my all motor nitrous car , and thousands of people do ,
and thats is what you should do too .
EDIT you can run crome also , it dont matter , but your question is crazy we cant give you a base map , unless you have that program
Modified by 00-501itrspec at 7:47 PM 4/9/2008
would it be better to just use my p30 than getting a p28? should i use crome? what would be the best thing to do. i dont want to ruin this motor. my plugs are burnin white...
