Damn black smoke...
Old Apr 9, 2008 | 05:07 AM
KnuckleZ's Avatar
Default Damn black smoke...
I have a 98 B18C5 that smokes (black) at high RPM's and leaves a residue. Black means running rich so I checked a couple of things and found out that the thermostat was bad and the car was running too cold and it took too long to warm up. So i fixed that, changed the fuel filter and did the timing belt and water pump. The engine feels a lot better but I'm still getting some smoke. What else could be causing this problem?
Thanx
Old Apr 9, 2008 | 05:11 AM
Ed 341's Avatar
Default Re: Damn black smoke... (KnuckleZ)
Worn piston rings most likely, or valve seals.
Old Apr 9, 2008 | 05:13 AM
KnuckleZ's Avatar
Default Re: Damn black smoke... (Ed 341)
Wouldn't that be blue smoke?
Old Apr 9, 2008 | 06:55 AM
JOHN WAYNE's Avatar
is this a stock ECU?
Old Apr 9, 2008 | 07:34 AM
KnuckleZ's Avatar
Default Re: Damn black smoke... (JOHN WAYNE)
Yes it is.
Old Apr 9, 2008 | 07:43 AM
JOHN WAYNE's Avatar
do you have a cat or a test pipe?
Old Apr 9, 2008 | 07:56 AM
KnuckleZ's Avatar
Cat. No check engine lights if you're thinking one of the sensors.
Old Apr 9, 2008 | 07:58 AM
jgirard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KnuckleZ &raquo;</TD></TR><TR><TD CLASS="quote"> found out that the thermostat was bad and the car was running too cold and it took
I believe mine might be bad, how much did a new thermo run you? Sons acura's site is down
Old Apr 9, 2008 | 08:03 AM
KnuckleZ's Avatar
Default Re: Damn black smoke... (jgirard)
Like $20-25 IIRC.
Old Apr 9, 2008 | 08:04 AM
jgirard's Avatar
thanks
Old Apr 9, 2008 | 10:09 AM
robfrmny21's Avatar
son blk smoke at high rpm is not abnormal for any car. the fuel demand is high and at those speeds not all of the fuel is burned off or correctly.. if it is like a smoke screen then yes you have a issue
Old Apr 9, 2008 | 10:13 AM
tartje's Avatar
Default Re: Damn black smoke... (robfrmny21)
sigh
ALL standard cars will give out black smoke (unburnt fuel) at high rpm's
it's a Honda failsafe to protect the engine at high rpm's by overfueling a little. it's normal, stop worrying. I've followed brand new BMW 335i's that have done it even.
Old Apr 9, 2008 | 10:18 AM
The Dude's Avatar
Banned
Default Re: Damn black smoke... (tartje)
If it ain't smoking, it ain't a B18C5.
Old Apr 18, 2008 | 09:03 AM
ITR-965's Avatar
Default Re: Damn black smoke... (The Dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Dude &raquo;</TD></TR><TR><TD CLASS="quote">If it ain't smoking, it ain't a B18C5. </TD></TR></TABLE>
That right there is the gospel...
Old Apr 18, 2008 | 12:30 PM
R.Kelley's Avatar
troof
Old Apr 18, 2008 | 01:05 PM
itrdave's Avatar
Default Re: Damn black smoke... (R.Kelley)
A small puff of black smoke that can only be seen by somebody behind you staring directly at your tail pipe when you go to WOT is normal. If you can see the smoke in the rear-view mirror, that isn't 'normal', though this is what generally happens to B18C5's over time...
Old Apr 18, 2008 | 01:27 PM
00-501itrspec's Avatar
Default Re: Damn black smoke... (ITR-965)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR-965 &raquo;</TD></TR><TR><TD CLASS="quote">
That right there is the gospel... </TD></TR></TABLE>
LOL!!
Old Apr 18, 2008 | 01:31 PM
GO-FIGHT-KILL's Avatar
You should see the epic black/blue cloud that follows my car after every WOT session.
Old Apr 18, 2008 | 04:29 PM
typer_696's Avatar
Default Re: (GO-FIGHT-KILL)
I have a ninja cloud. Hit vtec and watch my car disappear with all the smoke I throw out.
Old Apr 23, 2008 | 11:55 AM
itr#1334's Avatar
So what if you don't have any smoke just black soot on your bumper?
Old Apr 23, 2008 | 04:21 PM
typeR#0427's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">You should see the epic black/blue cloud that follows my car after every WOT session. </TD></TR></TABLE>
mine is epic as well, nothing like having a smoke out with the diesel truck next to you
Old Apr 23, 2008 | 06:02 PM
The Dude's Avatar
Banned
Default Re: (typeR#0427)
I think a lot of it is the low-friction ring design on the C5. Mine started smoking at 45-50k miles. At 160k teardown, it was using oil bigtime, leakdown and comp. numbers were pretty bad (mostly on one cylinder) but the valve seals and guides were in good shape, so must of been the rings. And V-Tec surely adds to blowby. I ran Mobil 1 since break-in on the ITR.
For comparison I also ran Mobile 1 in a Gen 1 teggy that I bought w/50k miles and original owner had taken good care of. It burned 1/4 quart between changes.
At 200k it was burning 3/4 quart 'tween changes.
A grate lil' DD car.
(To affirm OG status, handling package I put on the Gen 1 teggy was Jackson Racing.)
Old Apr 24, 2008 | 04:12 AM
Ed 341's Avatar
Default Re: (itr#1334)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr#1334 &raquo;</TD></TR><TR><TD CLASS="quote">So what if you don't have any smoke just black soot on your bumper?</TD></TR></TABLE>
You're not driving hard enough.
Old Apr 24, 2008 | 08:52 AM
itr#1334's Avatar
lol i'll remember that. Nah drive it hard like once a week.
Old Apr 24, 2008 | 09:11 AM
Larkin W.'s Avatar
Woot for Smoke
After returning my 97' to D-stock legal (no more header/testpipe), smoke is a lot less, but it seems to be expected with higher mileage Hype R's
