how much oil in my trans
Old Apr 9, 2008 | 03:56 AM
the_rex's Avatar
Default how much oil in my trans
i have a b16 with a lsd y1 cable tranny how much oil am i supposed to put in and the only reason i need to kno that is because i changed my oil when i put in my new clutch
Old Apr 9, 2008 | 07:44 AM
sgallagher's Avatar
Default Re: how much oil in my trans (the_rex)
I believe its 2.5 quarts just get 3 quarts and use the fill and check hole on the side of the trans. Be sure to have the vehicle level when checking fluid.
1. Drain the trans using drain plug.
2. Reinstall drain plug. Remove fill plug.
3. Use a fluid pump to fill trans. When fluid starts coming out of hole reinstall plug.
Old Apr 9, 2008 | 11:08 AM
Gearspeed-Performance's Avatar
Default Re: how much oil in my trans (sgallagher)
Can't get any simpler than that. You don't exactly need a pump...you can use a funnel with a long/thin fill hose and do it from the top...takes some patience!
Old Apr 9, 2008 | 03:09 PM
tico's Avatar
Default Re: how much oil in my trans (Special Projects MS)
IF U DONT HAVE THE PATINCE FOR THAT I REMOVED MY BACK UP LIGHT SWITCHAND IT LEAVES A 1/2" HOLE IN THE TOP OF THE TRANNY. EASY AS HELL
Old Apr 9, 2008 | 03:29 PM
Ermil's Avatar
Default Re: how much oil in my trans (tico)
Holy crap. Why are you yelling?
Here' what I used. 1 Quart synchromesh, rest the OE stuff. Shifts great.
Old Apr 9, 2008 | 03:43 PM
beana's Avatar
you can use the reverse light sensor to fill it but use the fill plug to check the level .it's on the passenger side of the diff use just a 3/8 ratchet with a 3 in or stubby exstention NO SOCKET when the oil comes out the fill plug put the plug back in
Modified by beana at 4:49 PM 4/9/2008
Old Apr 9, 2008 | 04:46 PM
nitewolf's Avatar
Default Re: how much oil in my trans (Ermil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ermil &raquo;</TD></TR><TR><TD CLASS="quote">Holy crap. Why are you yelling?
rest the OE stuff, whats that
Old Apr 9, 2008 | 04:48 PM
zccr-xsi's Avatar
u know your not suposes to mix anythijng with snyrcomesh.
Old Apr 9, 2008 | 05:02 PM
nitewolf's Avatar
Default Re: (zccr-xsi)
x2
Old Apr 9, 2008 | 05:07 PM
onemore's Avatar
man i went to get some synchromesh the dealer wanted 20 for a quart.
Old Apr 9, 2008 | 05:20 PM
Johnny-Red's Avatar
Default Re: (onemore)
Penzoil makes a synchromesh, same thing as the GM synchromesh. 7 bucks a quart. you can ind it any auto store works fine.
Old Apr 9, 2008 | 05:26 PM
zccr-xsi's Avatar
Default Re: (Johnny-Red)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny-Red &raquo;</TD></TR><TR><TD CLASS="quote">Penzoil makes a synchromesh, same thing as the GM synchromesh. 7 bucks a quart. you can ind it any auto store works fine.</TD></TR></TABLE>
thats what i use
its the same stuff u buy from the chevy dealer but the dealer **** is modified syncromesh if u look on the bottle all the tranny part numbers are the same.
sublimeh215
Mar 24, 2009 04:39 PM
EF-Boy91
Oct 8, 2006 05:22 PM
EJ8 GSR-T
Sep 4, 2005 11:59 AM
vics_si
Aug 4, 2005 04:47 PM
Understeer
Mar 19, 2004 09:59 AM
