Who uses camber kits??
Old Apr 8, 2008 | 11:15 PM
EF_9's Avatar
Default Who uses camber kits??
hey i was wondering when you drop your car do you put a camber kit on or you dont use one at all. just curious
Old Apr 8, 2008 | 11:22 PM
EGfosho's Avatar
OG Tech
Default Re: Who uses camber kits?? (EF_9)
WTF. If you have a camber problem and your tires are going bald on the inside, get a camber kit. If your camber is straight up and down and even tread across the tire, do not worry about. When you lower the vehicle, your camber usually goes negative and causes uneven tread on the tires. Every time you lower or raise the vehicle, you have to get an alignment done.
Old Apr 8, 2008 | 11:26 PM
EF_9's Avatar
Default Re: Who uses camber kits?? (EGfosho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGfosho &raquo;</TD></TR><TR><TD CLASS="quote">WTF. If you have a camber problem and your tires are going bald on the inside, get a camber kit. If your camber is straight up and down and even tread across the tire, do not worry about. When you lower the vehicle, your camber usually goes negative and causes uneven tread on the tires. Every time you lower or raise the vehicle, you have to get an alignment done.</TD></TR></TABLE>
haha well said just wanted see any inputs on it
is it necessary to get one if the drop is like 2 maybe???
Old Apr 8, 2008 | 11:31 PM
lv6l's Avatar
well drop it and see if it effects your tires. if not. why waste the time and money. some may change the cambers from a 1" drop, some may be sitting just fine from a 2" drop. i never had to; i drop by close to 2"
Old Apr 8, 2008 | 11:33 PM
EF_9's Avatar
oh alright for show
Old Apr 8, 2008 | 11:35 PM
DOHChatchGUY's Avatar
it just depends bud. sum cars are different. i dropped my hatch maybe like 3 inches and i have sum camber on the front but not in the back. but my friend's integra has a grip of camber in the front and back. i bought sum falken ziex 512's and they lasted like 10,000 HARD-DRIVEN miles. not too bad i guess but i would rather have a camber kit in the front if i could, and i will get one eventually.
Old Apr 8, 2008 | 11:40 PM
EF_9's Avatar
my old hatch needed one in the front tires went by quick with 195 65's
Old Apr 8, 2008 | 11:47 PM
EJAYATE's Avatar
I Deliver
I use camber kit on any drop, lowest was -4.35in on my coupe. I only get 5k out of rt-615.
Old Apr 9, 2008 | 02:45 AM
civickiller's Avatar
Default Re: (EJAYATE)
most important, get you toe fixed, that causes most tire wear
Serge L
Suspension & Brakes
Mar 30, 2012 12:26 PM
89MA70
Suspension & Brakes
Aug 11, 2008 01:01 PM
98GSRDC2
Suspension & Brakes
Aug 17, 2007 11:10 AM
E36 Guy
16
Apr 7, 2006 09:58 AM
BigDawwg6969
May 29, 2005 11:42 AM
