Play in the my steering wheel (94 Accord EX Coupe)
Old Apr 8, 2008 | 06:42 PM
m0nee's Avatar
Default Play in the my steering wheel (94 Accord EX Coupe)
Anyone have this problem? I don't know whether it's in the steering column, or in the steering wheel, but there is play in my steering wheel at all times. Like loose, free play. It's not a side to side play or in and out play like in a bad turbo, but you can turn it left and right about 1.5" each way until you feel the tension turning the wheel. So it has about 3 inches of free play. Do I make sense? What is wrong here??
Old Apr 8, 2008 | 08:31 PM
m0nee's Avatar
Default Re: Play in the my steering wheel (m0nee)
help?
Old Apr 8, 2008 | 08:48 PM
dleccord's Avatar
sounds like a hydraulic seal in your steering rack.
Old Apr 9, 2008 | 06:01 PM
m0nee's Avatar
Default Re: (dleccord)
Where exactly is that located?
Old Apr 10, 2008 | 05:19 AM
SlammedAccord96's Avatar
Default Re: (m0nee)
I'd jack up the front of the car, grab the rim and shake it left to right, if you feel play then have a friend do it while you look for the loose part, inner or outer tie rod. If not, then it might be rack play like dleccord said and you'll need a new steering rack.
Old Apr 12, 2008 | 02:20 AM
dleccord's Avatar
my accord has about .5 to an inch of play, swinging on the vertical axis that is when the wheels are off the ground. inspect the boots and see if there's any fluid leak around. the inside should have some kind of grease but not as much as you would expect from a cv joint. if there is a leak, the steering rack should be replaced; rebuilt ones are about 2-300 without labor.
Old Apr 12, 2008 | 02:21 AM
dleccord's Avatar
forgot to mention you could do the seals yourself but expect a whole lot of heap though.
beans45883
Jun 16, 2017 06:35 AM
PrettyMuchBoned
17
Apr 28, 2014 12:25 PM
CDStreetSleeper
Mar 17, 2013 10:34 PM
tianporn
Jun 16, 2004 08:25 PM
