b16 transmission question
Old Apr 8, 2008 | 05:28 PM
ole' black crx's Avatar
Default b16 transmission question
i have a b16a with a cable trans and am wondering if an aftermarket clutch and flywheel made for the b16 trans will fit on a cable and hydraulic the same. is there a difference? the engine is a swap so i dont know exactly what car it is from or what year the transmission is.
Old Apr 8, 2008 | 08:20 PM
gunnerman's Avatar
Default Re: b16 transmission question (ole' black crx)
look at the trans from the engine bay..there should be a sticker on top of it.
for a b16a cable you will use the same clutch for a 90-92 integra LS. small spline trans clutch and flywheel. PM is you're interested in a used exedy 12lb flywheel.
Old Apr 9, 2008 | 02:30 AM
civickiller's Avatar
Default Re: b16 transmission question (gunnerman)
the only usdm b16 trans is hydro. depending which b16 trans you have, depends which clutch.
YS1 = big spline, uses hydro clutches
s1,j1,y1,a1 = small spline, uses 90-91 integra clutch
Old Apr 9, 2008 | 06:26 PM
Default Re: b16 transmission question (civickiller)
what about aftermarket LSD? what will work with my Y1 tran? do i still need to get one that works with a 90-2000 Integra LS/GS and 92-93 GS-R?
EG6_LS_BOOST
Jul 8, 2013 01:30 PM
AllMotorAri
Aug 14, 2012 10:16 AM
viper_linx
Northern California (Sales)
Mar 20, 2011 08:56 AM
freakin_eLRoD
May 6, 2007 09:41 AM
