hard acceleration=loss of clutch!!!!!!
Old Apr 8, 2008 | 05:11 PM
95ludeSE_bottle's Avatar
Default hard acceleration=loss of clutch!!!!!!
heres the deal- i've recently noticed my clutch becoming a little "loose" - at first i thought it was jsut in my head or maybe because i jsut got a new pair of shoes and everything feels different......but thats not the case- if i shift from 1st to 2nd to 3rd under hard acceleration by the time i get to third i have no clutch left- i cked the reservoir and its full--- is my clutch is going out or what? any ideas or information will be appreciated..............
Old Apr 8, 2008 | 05:52 PM
H22Luda720's Avatar
Default Re: hard acceleration=loss of clutch!!!!!! (95ludeSE_bottle)
Explain "no clutch" better
Going to the floor?
Possible Slave Cylinder
Old Apr 8, 2008 | 06:08 PM
Default Re: hard acceleration=loss of clutch!!!!!! (H22Luda720)
yes going to the floor....it has nothing but slack- and it only does this under hard acceleration. its a 95 model with under 100k miles on it.
Old Apr 8, 2008 | 06:21 PM
shadow29485's Avatar
Roll at 40mph in 5th, dump the gas w.o.t. What happens? Does your rpm rise, but not your speed/acceleration???
I believe "Matt" helped me with a similer problem a while back.
That's what he suggested.
Old Apr 8, 2008 | 07:39 PM
Default Re: hard acceleration=loss of clutch!!!!!! (shadow29485)
rolled at 40 mph- hit the accelerator- rpm rose with mph- i'm thinking its not the clutch but a master or slave cyclinder........has anyone else had this problem? has anyone else had to change out the master or slave cyclinder? if so, how much was the parts and how difficult was the install? i'm planning on going to the coast in 4 days and i need my clutch!! any help is appreciated..thanks in advance........
1995 lude se
msd wires 8.5 mm
msd cap/rotar
ngk irridium plugs
aem CAI
apexi N1 Exhaust
DC Sports header
NOS (50 shot)
Old Apr 9, 2008 | 08:35 AM
H22Luda720's Avatar
Pull back the boot on the slave cylinder, should be able to see if its leaking.
Slave cylinder is easy to change, 2 bolts and the line, will make it alot easier if you have someone to help you bleed the system.
Old Apr 9, 2008 | 12:29 PM
bluedlude's Avatar
you slave/master cylinder isnt doing anything when you foot is off of the clutch.
Old Apr 9, 2008 | 04:51 PM
Default Re: hard acceleration=loss of clutch!!!!!! (bluedlude)
i noticed something else today- clutch seems ok if driving at slow speeds- pushing it hard to bout 90-95 and the clutch seems to disapear.... feels the same as if have air in ur brake line b4 u bleed them- real spongy- i got a slave cyclinder today from auto zone and gunna pk up the master tom- gunna replace them friday and see if that works...........
Old Apr 9, 2008 | 04:56 PM
bluedlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude &raquo;</TD></TR><TR><TD CLASS="quote">you slave/master cylinder isnt doing anything when you foot is off of the clutch. </TD></TR></TABLE>
the only thing your clutch slave and master cylinder do is engage or disengage the pressure plate with the clutch pedal. the second you let up on the clutch they arent doing anything anymore. not sure of the symptoms of a bad pressure plate, but it sounds like the clutch disk could be badly glazed over.
Old Apr 9, 2008 | 05:05 PM
i understand if ur not on the clutch the cyclinders dont do anything.............however if u have a crap load of slack in the clutch i am assuming the cyclinders are out----when the slack occurs, i have to press to the floor on the clutch to get it to catch..... my clutch has never slipped- and when its acting up if i pump the clutch a cpl times it works fine...........again i am thinking it the master or slave cyclinder............am i wrong????????????????????
Old Apr 9, 2008 | 05:09 PM
bluedlude's Avatar
well thats completely different from what you have been describing. why font you try adjusting the pedal first
Old Apr 9, 2008 | 07:12 PM
RaysBoomBoomLude's Avatar
dude,
RELAX
with the car,off, pump the clutch.
is there a leak? does it get harder? softer?
the clutch should NEVER be soft, or get extremely hard.
the pedal should return on its own, if it doesnt. somewhere in the hydro system is [freak]ed.
GET A MANUAL
vactor
Honda S2000
31
Jan 4, 2014 04:46 AM
y0whuddupb
Sep 6, 2005 01:11 AM
imonx850
Aug 17, 2005 07:27 PM
jdmteg95
Dec 17, 2002 03:52 AM
LOwrestling2001
May 26, 2002 03:28 AM
