TEG OEM BODY KIT Owners, Quick Questions
Old Jul 10, 2002 | 07:31 PM
Comptech98GSR's Avatar
Default TEG OEM BODY KIT Owners, Quick Questions
2 questions,
1. Did u have to drill holes for the front lip, to be mounted properly
2. how did the clearance change from before installing the lip, as far as scratching it up on driveways etc.
thanks. dc
Old Jul 10, 2002 | 07:35 PM
mattL's Avatar
Default Re: TEG OEM BODY KIT Owners, Quick Questions (Comptech98GSR)
no noticable drilling on the front lip, the rear parts require making holes in the bumper, as for clearance yes you will need to be more carefull, i't lowers the front down about a 1 1/2 inches plus it changes the shape of the front making it flat instead of lip up. worth it for the look though
Old Jul 10, 2002 | 07:49 PM
satintegra's Avatar
Default Re: TEG OEM BODY KIT Owners, Quick Questions (mattL)
1. 2 holes to drill, but you don't have to drill it.
2. with the lip, it sits about 1/2 inch lower. not too drastic.
Old Jul 10, 2002 | 11:40 PM
Mr. Thunderlips's Avatar
Okay, since I am the worst person when it comes to scraping lips...My problem came on the sides when I was parallel parking, or just pulling up to curbs. I'd always scrape the sides cause they stick out a little further. I also have a killer driveway, so the bottom got scraped up, but it was underneath. For the sides, just line the lip up, use a pushpin to start the hole, then just thread the screw with a screwdriver, no drill needed.
[Modified by ThunderLips, 12:40 AM 7/11/2002]
ch0baca
Oct 24, 2008 01:24 PM
ThErAcK
Aug 9, 2004 08:01 PM
chris215chris
May 7, 2003 05:43 PM
Comptech98GSR
Jul 11, 2002 05:06 AM
