Obd1 engine harness, obd2 distributor and jdm h22a questions
Old Apr 8, 2008 | 03:56 PM
h22a_93accord's Avatar
Default Obd1 engine harness, obd2 distributor and jdm h22a questions
i have a 93 accord and i am putting a h22a jdm engine in it. The h22a takes a obd2 distributor. How can i get the obd2 distributor to hook up to my obd1 harness out of the accord???? Thanks
Old Apr 8, 2008 | 06:05 PM
98vtec's Avatar
moderator emeritus
Default Re: Obd1 engine harness, obd2 distributor and jdm h22a questions (h22a_93accord)
Do you have an OBDII engine?
if you have an OBD1 engine with an OBDII distributor, then you must have the crank sensors that are located on the oil pump as well as the OBDII crank timing gear and OBDII balancer shaft gear.
Old Apr 10, 2008 | 08:42 PM
C_Rock77's Avatar
Don't try to use the OBD2 Dizzy. Just find an OBD1 Dizzy and sell the OBD2 one. That'll save a LOT of pain in your ***!
h22a_93accord
Apr 8, 2008 04:11 PM
julianaa
Oct 3, 2007 12:43 PM
jetlude
Sep 13, 2005 12:56 PM
Astr8upfella
Jan 21, 2002 10:53 AM
Astr8upfella
Jan 20, 2002 01:30 PM
