Speedo accuracy: Tire size, or Engine/tranny?
Old Jul 10, 2002 | 07:28 PM
Jonathan_ED3's Avatar
Default Speedo accuracy: Tire size, or Engine/tranny?
i have a b18b1 in my '92 CX...and I know my speedo accuracy is off. My question is this:
Which is the cause of my speedo being off.....my b18b swap, or my tire size? I'm running 185-65-14's...but the OEM CX size is a 13"....does my engine/tranny combo have anything to do with the speedo accuracy?
If I change back to the stock CX tire/wheel combo, will my speedo go back or to get it to read correctly do i need the stock Integra RS/LS tire size? The Speedo reads off the transmission I think, so would I need the Integra size tires to get a correct reading or is my thinking off?
Old Jul 10, 2002 | 07:51 PM
tinkerbell's Avatar
Default Re: Speedo accuracy: Tire size, or Engine/tranny? (hot_EF)
this might help...
http://miata.net/garage/tirecalc.html
t..
Old Jul 10, 2002 | 07:56 PM
Default Re: Speedo accuracy: Tire size, or Engine/tranny? (tinkerbell)
this might help...
t..
yeah that would help if i knew whether i needed the equivalent of a stock LS Integra tire or if i need a stock '92 CX size? anyone know which affects the speedo...the engine/tranny combo or JUST the speedo itself (which would mean i need stock CX tires, not integra size)?
Old Jul 10, 2002 | 08:01 PM
tinkerbell's Avatar
sorry, misunderstood,
the tranny tells the speedo how fast it is spinning (static),
the tires tell the tranny how fast it is driving (dynamic).
so all trannys tell the speedo how fast its wheels are spinning based on the stock tyre diameter.
if you wnat speedo accuracy get stock diameter tyres.
t..
Old Jul 10, 2002 | 08:04 PM
t..
yes..exactly my point BUT:
do i get stock INTEGRA diameter tires OR stock CIVIC diameter tires? I have an Integra b18b engine in my '92 Civic. so which would i get?
Old Jul 10, 2002 | 08:07 PM
tinkerbell's Avatar
id say stock civic...
but it is all pretty similar,
im running a b16a in a 83 prelude with 205/45ZR16's and hte speedo is perfectly accurate.
t..
Old Jul 10, 2002 | 08:09 PM
i'd really like a definitive answer....anyone else know? if it's stock civic i gotta hunt down some 13" wheels
Old Jul 10, 2002 | 08:13 PM
tinkerbell's Avatar
no you dont.
you need tyres that have the same outside tyre diameter
not same wheel diameter.
that is why the link above is most useful.
if you have stock CX tyres that are 185/75R13
then if you want 14 inch wheels use 185/70R14 tyres.
simple.
t..
Old Jul 10, 2002 | 08:16 PM
well the problem is i don't know what the stock CX size should be other than it's on a 13" rim....if i knew, then yes, i could figure it out..but i don't know
Old Jul 10, 2002 | 08:17 PM
tinkerbell's Avatar
sorry - neither do i,
ask your local Honda dealer...
t..
Old Jul 10, 2002 | 08:20 PM
well i'm trying to find out in the EG forum....but you're pretty sure it should be stock civic size even though i have a Teg engine (which would come with bigger tires of course) ?
Old Jul 12, 2002 | 07:49 AM
e_SolSi's Avatar
stock tire size for a 92 CX is 165/70-13..... overall diam. is about 22.2" with about 947 revs per mile... those measurements wont be exact for all tires but its a decent guideline. hope that helps
oh yeah the integra is a 195/60-14 OD=23.2" rev per mile = 898
[Modified by e_SolSi, 4:54 PM 7/12/2002]
Old Jul 15, 2002 | 10:46 PM
Default Re: Speedo accuracy: Tire size, or Engine/tranny? (e_SolSi)
hey thanks! i heard somewhere else that the stock CX size is 175-70-13....can you confirm that it's 165-70-13 and not 175-70-13?
also, is the final word that my speedo determines the accuracy and i should get an OEM CX equivalent tire size even though the tranny is an Integra?
Old Jul 16, 2002 | 08:55 AM
e_SolSi's Avatar
I checked out 3 tire web sites and all agreed with that size .... the 175/70-13 is for the DX check out tirerack or any other tire site it will tell you the stock size for just about any car
nomad_G3 Turbo
Jan 4, 2006 02:21 PM
FD3S
Oct 8, 2005 01:43 PM
mr.beeks
Jan 2, 2005 02:23 PM
quickda6
Jun 6, 2003 03:21 PM
turbofed EX
Oct 23, 2002 09:34 AM
