B16A Idle Problem
Old Apr 8, 2008 | 02:47 PM
SinsEvil666's Avatar
Default B16A Idle Problem
Well im working on a project but until now i need to have my b16 running and maintained since its daily driver.
Everytime i turn on car, Idle is between 2100-2800 rpm when cold (somedays is differente, but stays within that range)
once its warm, it stays around 1100-1500 rpm
Did some readin, and seems like i should replace or clean both, IACV and the FITV. also, i need to check for vacum leaks...well
problem is i never done this before but i need to do it and learn. Anyone has a write up on IACV, i printed out the FITV DIY in how to clean it and remove it, anyone have a guide on doing so for the IACV.
Another thing, how can i check for vaccum leaks?
Help greatly appreciated. Thank You.
Modified by SinsEvil666 at 10:59 AM 4/9/2008
Old Apr 9, 2008 | 09:58 AM
Anyone on how to check for vacumm leaks?
i will be buying some throttle body cleaner and spraying it around the manifold/gasket to see if any leaks from there....but as for vacumm leaks...im still at point blank on what do i need and how to check for leaks.
Edwin909
17
Apr 21, 2011 07:46 PM
hondachris1994
Feb 20, 2006 07:14 PM
Irish Integra
Mar 31, 2005 02:30 PM
ls-t del sol
Sep 27, 2004 11:49 AM
trvrx_na
Jul 12, 2004 01:14 PM
