BUNCH of stuff for sale, CRX lights, D-series spare heads/valvecovers/headers, and more!
I have a TON o stuff floating around my shed right now that I need to get rid of:
I have:
a BRAND NEW D-Series megan racing 4 into 1 header, $100
a USED no-name D-Series 4/2/1 Header, $40
a set of BRAND NEW 88-91 CRX Clear Corners
a set of BRAND NEW clear lower front CRX turn signals (one has a broken clip IIRC) $10
a set of used OEM corner turn signals off an 88 CRX (still in good condition) $10
a 92-95 Civic CX transmission with a bad main bearing $30, shifted smooth when pulled (VERY easy fix, GREAT gasmileage transmission)
I have a 1 year old Civic CRX SI battery (high end Exide IIRC) $40
I have a 94-01 integra Rear T-bracket for AUTOMATIC cars (will not work on manual ones) $15
I have a 92-95 D-Series civic rear T-bracket $15
a 1992 D15B8 (8 valve) head, in perfect working order, pulled for a mini-me swap with 92K on it. $40
a 94 D15B7 head with no cam, and a broken bolt in one of the cam holder spots *springs/retainers can still be used, or can be used for porting if you EZ out the one bolt *again, easy fix* $30
a 94 D15B7 intake manifold, mostly bare $15
92-95 D-series NON vtec valve covers *I think I have 2, they both need a repaint, but would be perfect for it* $15 each.
used OBD1 D-series Ignition coil, pulled for Accel HEI coil upgrade, $20
I will post pictures as soon as I can, if you have a question about something, PM me, or email me (dasfinc@hotmail.com) and I can get you a picture sooner.
Modified by Dasfinc at 10:58 AM 4/10/2008
I have:
Dasfinc
Apr 29, 2008 06:19 PM
